   / Share Pics of People Hauling or Towing Something Wrong #11,561
Wide lanes, straight roads. Not seeing those here. :thumbsup:
Like driving in a Walmart parking lot :D
   / Share Pics of People Hauling or Towing Something Wrong #11,562
Look close in the second pic. He has a second strap. It is yellow and blends into the bale pretty good.
I see that now, I would have probably still ran another to make a loop around the bale and pull it to the left, but that's just me.
Aaron Z
   / Share Pics of People Hauling or Towing Something Wrong #11,563
^^^^ I will agree that it could have been loaded better, and one strap too many is better than not enough
   / Share Pics of People Hauling or Towing Something Wrong #11,564
They probably are OK even with the top one leaning. The lateral strap (front to back) is cinched down into the bale, so it isn't going anywhere unless something breaks.
Other than being about 1000# over the weight limit of the trailer if that is a the normal 3500# axle and not a 5200# axle
   / Share Pics of People Hauling or Towing Something Wrong #11,566
   / Share Pics of People Hauling or Towing Something Wrong #11,567
Most people put those on dually trucks. Even if it wasn’t way too heavy it’s way too long. I don’t imagine the truck had any steering or stability at all. What an idiot.
Maybe they should have had more weight up in the bed area before hitting that big dip in the road?
   / Share Pics of People Hauling or Towing Something Wrong #11,568
It would have probably helped but according to the article that camper was already 2800 pounds. Way too much for a 150.
   / Share Pics of People Hauling or Towing Something Wrong #11,569
Being that it is not squatting too bad, I'm assuming that the rear suspension had been heavily modified.:confused2:
   / Share Pics of People Hauling or Towing Something Wrong #11,570
Thank god that little brown swoosh on the camper matches the truck paint. Otherwise that would have looked hideous. Neve used one, but I think those campers are practical and great. If put on a 3/4 or 1 ton!
   / Share Pics of People Hauling or Towing Something Wrong #11,571
Or if put on a trailer which is pulled by a half ton pickup.
   / Share Pics of People Hauling or Towing Something Wrong #11,572
   / Share Pics of People Hauling or Towing Something Wrong #11,573
That looks way better. Those things would have to drive awful plus your door is 5 feet off the ground.
The neighbor has a huge Lance camper in a crew cab, long box, one ton, dually. For me, towing a trailer looks safer.
   / Share Pics of People Hauling or Towing Something Wrong #11,574
I can just about guarantee that F150 doesn't have 2000 lbs of payload either, more like 1500 lbs or less.
   / Share Pics of People Hauling or Towing Something Wrong #11,575
This load weighs more than a camper but the load center is a lot lower. It’s still pretty top heavy. I can’t imagine how awful one of those must drive. IMG_7859.JPG
   / Share Pics of People Hauling or Towing Something Wrong #11,576
To me it just makes more sense. A place to sleep and make something to eat. Don't need to pull a house behind you!
   / Share Pics of People Hauling or Towing Something Wrong #11,577
It would be cool if they made a rail mounted system where you could easily take off your bed and put on a camper. Or flatbed.
   / Share Pics of People Hauling or Towing Something Wrong #11,578
That would be cool! I would be interested in something like that for my F150.
I recently took the bed partially off to fix the front wall that separated from the bed. Riveted it back together. Used a Cherry Picker and it was a bit of a pain to lift and slide back to access.
   / Share Pics of People Hauling or Towing Something Wrong #11,580
Is it just a coincidence that the black, blank section behind the rear fender is EXACTLY the length of the rear doors? Was that the "One Size Fits All Models" feature?
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
iDrive TDS-2010H...
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
2019 FORD F-150 XLT CREW CAB TRUCK (A59823)
2019 FORD F-150...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2019 INTERNATIONAL...
