They can stick Bobcat tractors where the sun don't shine.
   / They can stick Bobcat tractors where the sun don't shine. #11
That really sucks.
I agree with others who suggest that parts are likely still available and a "good" mechanic should be able to get you running again.
BTW, one reason I got an LS was that LS makes the same engine for the New Holland line. Down the road, I should be able to get parts even if my dealer goes belly up. Hope that never happens as I have an excellent dealer.
Wishing you luck.
   / They can stick Bobcat tractors where the sun don't shine. #12
To me, it's an age where buying companies and market share is more important than the products themselves. Did Bobcat really need a tractor line? I mean, for years they even poo-pooed them in favour of a skid loader.
   / They can stick Bobcat tractors where the sun don't shine. #13
Boy am I glad I have Kubota's 2002 and 2004 M9's and every part is available from the dealer and aftermarket parts abound too.
   / They can stick Bobcat tractors where the sun don't shine. #14
I saw a video of a guy working on a ten year old JD Mini-Ex that parts were "apparently" no longer available for.
   / They can stick Bobcat tractors where the sun don't shine. #16
You always have been so helpful.
   / They can stick Bobcat tractors where the sun don't shine. #17
I have a question.
How does it work with a new replacement engine on a pre tier IV tractor.
I'm assuming any new (new, not rebuilt) replacement engine must be tier IV compliant ?
   / They can stick Bobcat tractors where the sun don't shine. #18
I have a question.
Availability of new complete prior engines varies widely. Generally speaking if a new complete Tier III or older engine is available the replaced engine must be returned or verification that it has been rendered unrepairable is required. Usually they replaced engine serial number is documented when the new engine is ordered.
   / They can stick Bobcat tractors where the sun don't shine. #19
Pray tell: Why is the cylinder dead ? Stuck valve, broken rod, cracked rings, missing piston, block defect ? A biopsy would help this discussion. Everything is fixable IMHO. Heck, buy another one, swap motors, return the 'new' one because the motor is bad with less than 5 hours on it. Full refund please. Then tell us how wonderful your 10 year old hybrid is running !
   / They can stick Bobcat tractors where the sun don't shine. #20
Thanks Rick.
2015 Chevrolet Equinox SUV (A50324)
2015 Chevrolet...
2015 INTERNATIONAL 4300 26 FT NON CDL BOX TRUCK (A51219)
2015 INTERNATIONAL...
2021 CATERPILLAR 299D3 SKID STEER (A51242)
2021 CATERPILLAR...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
1985 International X Con Semi (A50514)
1985 International...
1999 INTERNATIONAL PAYSTAR 5000 TANDEM AXLE DUMP TRUCK (A51222)
1999 INTERNATIONAL...
