What do you call this "nut"?
/ What do you call this "nut"? #1
tallyho8
Super Member
North of the Gulf of America, west of Westwego
Kubota L4400, Kubota ZD326
I saw these on Amazon a while back while looking for something else and now I don't remember the proper name to search for them.
I need to buy some for my joystick. They have threads on 4 sides so you can mount the joystick facing up or out.
What's their name?
/ What do you call this "nut"? #2
Barrel nut. You could drill and tap threaded couplers also.
I just extended my joysticks with threaded couplers and ready rod. Here is what I just did yesterday.
/ What do you call this "nut"? #3
Mine were 10mmx1.5.
I did it this way for strength. I still need to put blue loctite on the threads.
I don't need to extend them. I need to change the direction they point 90 degrees.
A barrel nut only has holes on 2 sides. I need a nut with threaded holes on 4 sides.
/ What do you call this "nut"? #5
Ok got ya I mis read it.
/ What do you call this "nut"? #6
Buy two. Weld one across the end of the other.
Or weld a bolt on the side of the nut. Depends on the gender of your hardware. :)
Bruce
/ What do you call this "nut"? #7
Do you have enough clearance to use something like this? I've seen these with either pipe thread or bolt thread:
/ What do you call this "nut"? #8
On a Nortrac valve I found this on the nut you are looking for and it’s the same for 2-3-4-5-6 way directional valves and it appears to be part of another item, here is a diagram from Northern tool. It is item 19.
There is a phone number listed so you can call and see it that piece is available separately.
/ What do you call this "nut"? #9
give Surplus center a call they should know it's name and if it's in stock
Actually, I could use something as simple as this if I could find one with bolt thread to screw my handle into and then screw it into my valve to change the direction that my handle faces but I can not find one with the right thread.
/ What do you call this "nut"? #11
What's their name?
My question is where can I get replacement rubber boots for that same style valve?
/ What do you call this "nut"? #12
Standoff nut? But drilled the way these are will be hard to find...
looks like it would be easy to fabricate what you want
/ What do you call this "nut"? #15
It is probably number 18 on the parts breakdown I posted, wish it had part numbers but at least there is a phone number you can call.
I have solved my problem. I got my neighbor to bend the control rods 90 degrees in his press and I am then extending the rods with a coupler and threaded shaft as lmold did in post #2.
/ What do you call this "nut"? #18
Thank you for the suggestion!
Part #18 is actually part of a complete handle kit.
I only need the little rubber dust boots.
Three complete handle kits is way too expensive ($100+) to get 3 little rubber dust covers/boots.
2006 HEIL 200BBL CRUDE TANKER (A67714)
2006 HEIL 200BBL...
2005 MACK CHN613 (A67714)
2005 MACK CHN613...
2010 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A66736)
2010 Chevrolet...
FIRD MIXER TRUCK (INOPERABLE) (A67714)
FIRD MIXER TRUCK...
2011 CATERPILLAR CB434D DOUBLE DRUM ROLLER (A65056)
2011 CATERPILLAR...
2012 Ford Taurus Sedan (A66738)
2012 Ford Taurus...
