Kubota mx5200 first oil change. Book says 10 quarts, 6.75 came out..
   / Kubota mx5200 first oil change. Book says 10 quarts, 6.75 came out.. #1
MechanicalGuy
Beautiful South
Kubota mx5200
I put 8 quarts in and it is at the top of the dipstick full level. My manual says it holds 10 quarts. I changed the filter also. This has to be a typo in the manual. What are your experiences with the 5200 or the 5800?
   / Kubota mx5200 first oil change. Book says 10 quarts, 6.75 came out.. #3
I have a 2009 Kubota M6040. The Op Manual says 11.6 quarts with filter change. It actually takes 13.7 quarts with filter change. Go figure.......
Obviously an engineering estimate as opposed to a field trial.
   / Kubota mx5200 first oil change. Book says 10 quarts, 6.75 came out.. #4
Did you remove both drain plugs?
Both plugs.
Level concrete floor.
   / Kubota mx5200 first oil change. Book says 10 quarts, 6.75 came out.. #6
You won't ever get it all out. Some will remain in the trans itself, plus whatever is in the hydraulic lines, hoses, cylinders, etc.
   / Kubota mx5200 first oil change. Book says 10 quarts, 6.75 came out.. #7
When I do an oil change my MX5200HST will hold 8 qts also.
   / Kubota mx5200 first oil change. Book says 10 quarts, 6.75 came out.. #8
I think the OP is talking about engine oil not the hydraulic system.
   / Kubota mx5200 first oil change. Book says 10 quarts, 6.75 came out.. #9
No, it don't. OP is talking about engine oil, not hydraulic oil. Kubota is very vague about fill capacities on all their machines, mine included. Just use the dipstick and fill accordingly Mine calls for 12 quarts and it holds 13.5 with the filter on one machine, the other identical machine but 2 years older holds 12.5 quarts. I just go by the dipstick. Same with the hydraulic fluid level.
   / Kubota mx5200 first oil change. Book says 10 quarts, 6.75 came out.. #10
Most everything I own is like this. Including my Kubota.
I just fill it until it reaches the appropriate markings on the dipstick.
I also try to make it a habit of checking fluids before starting a machine -- especially one that has sat for a week or more.
I even check the fluids in all my vehicles every 3 days or so.
It's also interesting to note the color of the fluids too.
MERCURY VERADO ENGINES (A55758)
MERCURY VERADO...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
JOHN DEERE 648R LOT NUMBER 105 (A53084)
JOHN DEERE 648R...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A57024)
1992 Talbert 70...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
Uni-Carriers S1S1L15NV 3,000lb Electric Forklift (A55851)
Uni-Carriers...
