Kubota mx5200 first oil change. Book says 10 quarts, 6.75 came out..
/ Kubota mx5200 first oil change. Book says 10 quarts, 6.75 came out.. #1
MechanicalGuy
Beautiful South
Kubota mx5200
I put 8 quarts in and it is at the top of the dipstick full level. My manual says it holds 10 quarts. I changed the filter also. This has to be a typo in the manual. What are your experiences with the 5200 or the 5800?
/ Kubota mx5200 first oil change. Book says 10 quarts, 6.75 came out.. #3
I have a 2009 Kubota M6040. The Op Manual says 11.6 quarts with filter change. It actually takes 13.7 quarts with filter change. Go figure.......
Obviously an engineering estimate as opposed to a field trial.
/ Kubota mx5200 first oil change. Book says 10 quarts, 6.75 came out.. #4
Did you remove both drain plugs?
Both plugs.
Level concrete floor.
/ Kubota mx5200 first oil change. Book says 10 quarts, 6.75 came out.. #6
You won't ever get it all out. Some will remain in the trans itself, plus whatever is in the hydraulic lines, hoses, cylinders, etc.
/ Kubota mx5200 first oil change. Book says 10 quarts, 6.75 came out.. #7
When I do an oil change my MX5200HST will hold 8 qts also.
/ Kubota mx5200 first oil change. Book says 10 quarts, 6.75 came out.. #8
I think the OP is talking about engine oil not the hydraulic system.
/ Kubota mx5200 first oil change. Book says 10 quarts, 6.75 came out.. #9
No, it don't. OP is talking about engine oil, not hydraulic oil. Kubota is very vague about fill capacities on all their machines, mine included. Just use the dipstick and fill accordingly Mine calls for 12 quarts and it holds 13.5 with the filter on one machine, the other identical machine but 2 years older holds 12.5 quarts. I just go by the dipstick. Same with the hydraulic fluid level.
/ Kubota mx5200 first oil change. Book says 10 quarts, 6.75 came out.. #10
Most everything I own is like this. Including my Kubota.
I just fill it until it reaches the appropriate markings on the dipstick.
I also try to make it a habit of checking fluids before starting a machine -- especially one that has sat for a week or more.
I even check the fluids in all my vehicles every 3 days or so.
It's also interesting to note the color of the fluids too.
/ Kubota mx5200 first oil change. Book says 10 quarts, 6.75 came out.. #11
Kubota is very vague about fill capacities on all their machines, mine included. Just use the dipstick and fill accordingly Mine calls for 12 quarts and it holds 13.5 with the filter on one machine, the other identical machine but 2 years older holds 12.5 quarts. I just go by the dipstick. Same with the hydraulic fluid level.[/QUOTE]
/ Kubota mx5200 first oil change. Book says 10 quarts, 6.75 came out.. #12
[/QUOTE]
Sorry. Did not mean to reply to this posting. Fat fingers hit wrong button.
/ Kubota mx5200 first oil change. Book says 10 quarts, 6.75 came out.. #13
Maybe a dumb question, but did you run the engine before checking dipstick level? Filter will hold at least a quart, maybe more. Not sure about your machine, but on all of mine, engine has to run to fill the filter volume.
Yeah.
Thanks for the replies. I think it's a great machine it's just 2 quarts low to the manual which it super weird to me.
/ Kubota mx5200 first oil change. Book says 10 quarts, 6.75 came out.. #15
My ex wife accused me of being 2 quarts low as well.:laughing:
/ Kubota mx5200 first oil change. Book says 10 quarts, 6.75 came out.. #16
[/QUOTE]
Have you ever compared the dipstick lengths? The oil volume might not be wrong the dipsticks might.
/ Kubota mx5200 first oil change. Book says 10 quarts, 6.75 came out.. #17
Have you ever compared the dipstick lengths? The oil volume might not be wrong the dipsticks might.[/QUOTE]
I have in as much as I own 2 M9's, 2 years in build date apart and both dip sticks are the same length. Having said that, the operators manuals state different lube oil capacities.
/ Kubota mx5200 first oil change. Book says 10 quarts, 6.75 came out.. #18
As an FYI, as long as the transmission fluid level is just below the lower edge of the PTO output shaft on any Kubota (sitting on a level pad), the level is fine.
/ Kubota mx5200 first oil change. Book says 10 quarts, 6.75 came out.. #19
I've changed the oil twice so far on my MX5200. Both times I bought the 2.5 gallon container (10 qts) to cover the 9.9 courts as stated in the manual. Both times I had a lot left over. Probably about 2 quarts. Won't be buying the 2.5 gal anymore.
/ Kubota mx5200 first oil change. Book says 10 quarts, 6.75 came out.. #20
I buy all my lubricants, motor oil, hydraulic oil, gear oil and grease in quantity. Motor oil and hydraulic oil in 55 gallon drums, gear oil in 5 gallon pails and grease in 150 pound open head drums, all delivered to the farm by my supplier and my supplier takes my drained fluids too so recycling isn't an issue. been doing that for years.
2004 John Deere 544J Articulated Wheel Loader (A61572)
2004 John Deere...
2006 GODWIN GHP45KW-RC-45KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
Landa PGDC5-3500 (A64119)
Landa PGDC5-3500...
2022 Chevrolet Trax SUV (A61574)
2022 Chevrolet...
2007 Toyota RAV4 SUV (A61574)
2007 Toyota RAV4...
2026 Electric Tricycle (A64194)
2026 Electric...
