OP
RidgeHiker
Gold Member
- Joined
- Mar 23, 2011
- Messages
- 401
- Location
- Upper California Mountains
- Tractor
- Kioti DK5010 with KL5510 Loader & 72" Bucket. Kawasaki Mule Pro MX SE with 66" snow plow.
That can be one cause. Does the tractor have an electro hydraulic PTO or standard PTO? At full RPMs the electro hydraulic PTO will gradually start the PTO shaft, but a standard PTO will jerk that PTO shaft to start at full RPMs; this will weaken and break the shear pins on the PTO shaft. A lot people do not realize this, so if you do not know the type of PTO you have, turn PTO on at low RPMs and then rev up to full full RPMs and then attack the snow. For wet snow, as others have stated, go as slow as possible so you do not clog the chute. Worst case spay the chute and fan with fluid film or some kind of oil; even PAM will work. Good luck!
Interesting. I assume I have a standard mechanically driven PTO. The switch is electric. When it starts it appears to go to speed quickly. I'm one of the the "do not realize this" ones. Thanks for the tip on keeping the rpm lower initially. Have not broken any shear pins at startup but certainly could be stressing them.
Did some more blowing. Have been more careful what I am pushing it into and have not had a problem. Still working on adjusting the tilt vs keeping the shaft away from the quick hitch structure which meant tilting it back further than I like and was picking up a fair amount of dirt. Packed around the auger tightly but still did fine. Did some more resetting mounting onto 3 point and I think I have it set better but I will know more next time I run it. Been thinking about not using the quick hitch and getting telescoping lower lift arms but seem pretty expensive. With the blower weighing 755 lbs need something to replace quick hitch. Could get Pat's system but would also prefer not to push attachments back extra distance though a little less than my 3 point quick hitch.
