Bought a new Massey Ferguson 1735M
   / Bought a new Massey Ferguson 1735M #21
If you read the brochure about the tractor, it talks about the temperatures not being too elevated. This engine has been used in other equipment before this tractor and I have never read anything about any issues with it. I read all kinds of issues with engines that go through regen. So far so good for me.
I've read the brochure. I am not indicating there is anything wrong with the Massey engine at all. I would just like to understand the Massey system better. If they are not burning off the particulate, via a high temp cycle, then the system must be accumulating it in which case those accumulating devices would require replacement at some point. Of course, this assumption is based on lack of detailed info which the brochure does not provide. We must keep in mind that Massey points out the fact they don't use high temp burn cycles, but also do not provide clear information on how they do not. It's a bit of misdirection, or don't pay attention to the man behind the curtain. In the end, it's all word games.
   / Bought a new Massey Ferguson 1735M #22
Yes, the dealer told me the DOC would need to be replaced at something like 5000 or 10,000 hours. I cannot remember, but it is hours that I will never see :)
   / Bought a new Massey Ferguson 1735M #23
Similarly, a DPF will need to be replaced at some point too. I recall seeing an actual number recently, I think it was fairly high too. Regardless, I don't think I'd really worry about one emissions system over another. Each will have issues and may not be widespread systemic, but we really only hear on these forums about the horror stories. Nobody ever comes here to rave about how well their system works. To be honest, my shopping has me looking closely at Kioti and Massey at the moment and the emissions system is really not a major factor simply because I do not have enough long term or engineering information on either one. I'm shopping dealer, features, price, capability.
Understood, but the Massey does have the EGR/DOC system which I wonder doesn't present it's own potential issues. I thought I recalled reading somewhere that this engine EGR/DOC system runs hotter in order to circumvent the need for DPF. So it is burning off the particulate rather than capture it.
My understanding is, from talking with both the Mahindra service guys and the Massey Ferguson service guys, it has a lot to do with the design of the engines itself. From what I gathered it's a combination of an improved efficiency of burn from the compression ratio to the stroke length, the over 2,000bar direct injection fuel system which makes the diesel fuel practically turn into microscopic fuel particles for a cleaner and more even burn, the integrated EGR system to guarantee any left over diesel is burned again, and an improved turbo to further increase efficiency of the engine and reduce the need for more diesel as the revs go up. The less diesel left over after the burn stroke, the less emissions it will create. All of this "auto-magic" is controlled through the ECU. The DOC catches the last remaining unburnt particles and all that's left is just good ol' carbon monoxide and oxygen coming out the pipe. Heck, if it can pass California's emission tests, then it's as clean as it gets lol.
The other big tractor players out there need to get with it. DEF and DPF is starting to die off and better systems are on the way. Yanmar has some non-DPF models already, JD just need to get of their keister and get them in their tractors. Their service departments and their customers would surely be happier. Similar tidings to Kubota, Kioti, and the rest of the DPF'ers as well. Eventually, maybe, possibly, this tech will extend to the big boy engines down the road as well.
   / Bought a new Massey Ferguson 1735M #25
Got any updates? Went back and checked out and tested the 1735M again and saw a 1740M at another dealer. Have you done any dirt engagements like ripping or discing and how'd it do? My main concern would be where the loader hydraulics lines connections are placed right there behind the tire. Do you find that an issue?
Actually I do have some updates. For moving dirt it's really efficient at it. Matter in fact, even with ballast, the loader is able to pick up enough to make the rear bounce a little. My last tractor couldn't ever pick up enough to make it bounce. The loader is great at moving large amounts of dirt on this tractor and the hydraulics are fast and strong but a bit jerky when revved up but smooth when revs are low. I attribute that to the valve still being new. I have stalled it out a couple of times when I rammed it into hills of dirt with the bucket and picking up dirt at the same time when I'm using medium range but it didn't stall in low range. I also always used 4WD when I used the loader because the loads were so heavy the tractor would dig into the ground harder on turns with 4WD off vs on plus it handled better in general.
The loader hydraulic location hasn't been an issue and its even been smacked by limbs a few times already. Unfortunately the hydraulic couplers themselves is where my first major complain comes in. When they get smacked by a limb they pop out sometimes. Not a big deal at all if it wasn't stupidly difficult to put them back in. Even with hydraulic pressure released, the click in and click out design of the couplers suck to work with in my opinion. I wind up pushing on it 5 to 10 times to get them to catch and waste a handful of hydro fluid each time it happens. I would MUCH rather have standard pull back style locking collars instead of these click in/out type. They have down right frustrated me to put back in if they come out. Besides that, it has been great so far. It's a Cadillac of a tractor in comfort and features and a beast at work all around.
   / Bought a new Massey Ferguson 1735M #27
sweet. so the collars dont twist around and away from that tab to keep them from opening? Or is it a different design? This tractor is at the top of my list unless i go bigger.
The best way I can describe the hydraulic connections is like pushing a memory card in and out of a camera. You push them in and it's supposed to click in then you push on them again and they click out. Works great on electronic stuff but frustratingly difficult on hydraulic couplers.
   / Bought a new Massey Ferguson 1735M #29
Nice thing is you can change the connections if they are really giving you grief. Nice review by the way. I've been looking at these as well myself. I need a cab for winter duty myself and I'm sick of the open cab freezing. Finally sat in a kabota l3560 this year. And the price of this dealer was ridiculously high. Specced out same machine a half hour drive from me. And was almost 4500 cheaper. And he needed to order it. Nice thing is the massey ferguson has the defroster and rear wiper already added if I'm not mistaken to the cab.
   / Bought a new Massey Ferguson 1735M #30
It's odd that Kubota still differentiates the US and Canadian models. The Canadian cab models come standard with the rear window defrost, big alternator and wipers. No doubt we pay for that though, LOL But I wouldn't buy without it anyway.
I'm still amazed at the price fluctuations by dealer and region. I recently read a thread where someone got a John Deere cheaper than a Kubota! I have never seen that before, LOL.
   / Bought a new Massey Ferguson 1735M #31
I'm sure kabota has done a little research on their end. And probably find a majority would add them on already. I've spent way to much time in a cab tractor with little to no heat and zero window defroster to do it on my own unit. Not fun in subzero temperatures, frosting quicker then the heat is able to be produced.
It is amazing the price fluctuations by region. As for the John Deere being cheaper though. Only thing that would make sense is the dealer was sitting on it for a while. Or maybe it was a less desirable model?
   / Bought a new Massey Ferguson 1735M #32
Hello everyone. After lots of shopping, lots of statistical comparisons, lots of quotes, and lots of forum hunting and YouTube watching, I settled down on a new Massey Ferguson 1735M HST with a FEL, a 6' Bush Hog, and a 6' box blade. It was delivered earlier this week and I really love the tractor so far and hope it continues to be a good reliable tractor.
I made a YouTube video detailing everything on this tractor because there isn't many videos on it I noticed. Plus I prefer non-dealer videos. I also compared prices of quotes from other brands in the video. I even cover an issue I had out of the box, so to speak, with my bush hog.
This forum played a part of my buying decisions and I want to contribute back to it in some way so here's a link to my video and I hope it helps anyone who's currently shopping for a compact tractor.
New Massey Ferguson 1735M Overview, New Bush Hog Issue, and Other Tractors Price Comparisons - YouTube
I am a bit familiar with Kubota models and Kiota models and was leaning toward either of these but after all of the posts to my thread in the general section (link at the bottom), it looks like I need to put MF in the list too. But gad, it sure seems like there are a lot of models to choose from. I really like what you had to say about your model... are those same models available now and, are there other MF models that are similar? (same or close to same HP, features, etc) I guess I need to fid a site that compares the different MF models.
My thread:
https://www.tractorbynet.com/forums/owning-operating/420288-need-buy-tractor-concerned-about.html
As far as current models are concerned, (35-50hp), with the OP's features, I'm thinking I'm wanting the 1700M series or the 2600H series. Right?
My thread:
Either the 1700M or 2600H series tractors are good it really depends on your needs more than anything. Find a trustworthy dealer that has good service and a knowledgeable team and ask them for recommendations. All of the tractors I mentioned in my video are still available. I made the video around 3 months ago.
   / Bought a new Massey Ferguson 1735M #34
about to pull the trigger on a 1735m or 1740m - pls see my thread in the MF pricing section.
   / Bought a new Massey Ferguson 1735M #35
My thread:
It may or may not mean anything to you, however, the 2600 series are built in India. They come with different motors as well. The 1700 and 2700 series are built by Iseki in Japan. Ive read about QC issues with the India builds in general, not reffering to Massey.
Ive driven the 1735M and like it alot. It has all the bells and whistles and for that size it beats the competition IMO. I decided to look a little bit larger based on my needs.
Check out the 1739E as well. No fancy bits on them but youll pay alot less. Alot less than the competition as well. At least around here.
   / Bought a new Massey Ferguson 1735M #36
Lookin for an update on this machine. There痴 a lot I like about it. But,
Recently heard Massey is changing engines on these M series machines.
No more Shibaura, going to Iseki engines, and I知 guessing they will likely be equipped with DPF.
Anyone have some more info on this and how it could, or will, affect Massey support for owners with parts and repairs to their Shibaura engines???
Thanks
   / Bought a new Massey Ferguson 1735M #37
I've heard all good things about Iseki tractors, so I'd think that their engine in a MF ought to be good as well.
   / Bought a new Massey Ferguson 1735M #38
thanks, but not questioning the Iseki engine.
concern is the lack of support from Massey on an (out of warranty) engine they no longer source.
If a man needs parts, or worse yet, shop repairs on the Shibaura engine, where will he go?
Parts off the internet and a major shop repair to a Caterpillar dealer a hunnerd miles away?
Will Massey dealers still service and support these machines?
be handy to have some input from someone that has an inside line or is employed by Massey..................
   / Bought a new Massey Ferguson 1735M #40
There should surely be a good supply of Shibaura parts as well as people who know how to work on them. As a former Ford Tractor employee I know that Shibaura made the small Ford diesels for many years.
2005 GMC Canyon (A57148)
2005 GMC Canyon...
(APPROX. 20) 4' X...
159119 (A60430)
159119 (A60430)
2013 Land Rover Range Rover Sport 4X4 SUV (A55853)
2013 Land Rover...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
2016 CATERPILLAR D5K2 XL CRAWLER DOZER (A60429)
2016 CATERPILLAR...
