Drain plug help!
/ Drain plug help! #1
jasonzee
farmtrac555
I am updating my log spliter with more power so yesterday I was welding the nut on the bottom of the hyd.tank 1/2" nut. I used mig and 023 wire and 75 25 mix,today I cant turn the bolt all the way in so should I cool the nut when I weld another on? There no bbs that's stopping me I think the heat did something to the nut being small.
/ Drain plug help! #2
Run a 1/2" tap through the nut.
When I weld a nut on to some thing I put a lite coat of anti-seize on the bolt and screw it into the nut then weld the nut in place
/ Drain plug help! #3
I do the same with anti spatter spray.
/ Drain plug help! #4
Anti-seize or anti-spatter, and run tap through nut after weld cools.... Run a tap through threads is my usual go to fix after any welding on area that is threaded... Had not thought of actually having bolt in nut during weld, but I can see its benefits...
Dale
/ Drain plug help! #5
I always put a long bolt in the nut while welding to visually assure angles.
The bolt also assures no spatter on the threads.
/ Drain plug help!
I will try a tap never thought about that.
/ Drain plug help! #7
I just saw this thread title. Thought I was having a Kando flashback!
/ Drain plug help! #9
Welding the nuts tends to get them a little out of round. All info above is mandatory.
/ Drain plug help! #11
If you are welding on a nut over a matching hole to be used for a set screw then threading a bolt all the way through will align the nut, prevent spatter from damaging threads AND prevent nut distortion as yomax pointed out.
/ Drain plug help!
Yeah I should of threaded the bolt into the nut before welding because the bolt broke off!
/ Drain plug help! #13
Grab a seat and let the debate begin on pipe wrench vs infomercial tools.:rolleyes:
/ Drain plug help! #15
Weld it to seal it and weld another drain plug in the tank.
/ Drain plug help!
I welded it in the center of the box to make draining easy.I guess I can more it a few inches over.
/ Drain plug help! #17
This time use a weldable NPT spud like this so you can use a proper NPT drain plug.
Use antispatter and weld with new plug in fitting to avoid distortion.
/ Drain plug help! #18
YES....
At least something like half pipe coupler or whatever... Never liked bolts and nut as drain... Something with tapered thread was always better choice for me...
Dale
/ Drain plug help! #19
YES....
Look for products on pages at mcmaster.com.... 74, 75, 76, 77 Iron & Steel Pipe Fittings and Flanges78...
Dale
2017 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A65053)
2017 CATERPILLAR...
New Quick Attach Hay Spear (A65563)
New Quick Attach...
2021 Weber CF 2-IIHD Plate Compactor (A61572)
2021 Weber CF...
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F-250...
2022 SANY SY155U EXCAVATOR (A63276)
2022 SANY SY155U...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
