Third Functions Hydraulic Fittings Difficult to Engage
   / Third Functions Hydraulic Fittings Difficult to Engage #1
Woodsman603
North Country
Kubota L3710
Heyas.
Got an L3710 with a plow setup. Used Everything Attachment's third function kit. Works great, minus one caveat. The fittings by the plow side are incredibly hard to engage. I pull back the collar and insert the male into the female, and I have to use all my strength to get them to click into each other. The female side of the plow end is a 50/50 shot whether it goes in ok. Inserting the male end of the plow into the female of the tractor's third function barely goes in. It takes 5m of working it in there. By the end of it all, my arms and fingers are dead in the 10コ weather from getting them together. It sucks too, because I need to be able to keep swapping back and forth from the FEL to the plow, so I need to be able to click these on and off regularly.
I tried turning the tractor off thinking perhaps there is some pressure that is stopping them from connecting? Perhaps a little lithium grease inside the fittings? There anything else I could do? The fitting on the tractor end is brand new from EA. The plow side looks relatively new as well.
Suggestions? Thanks.
   / Third Functions Hydraulic Fittings Difficult to Engage #2
After you turn off the tractor, turn the key back to "on" and activate the 3rd function buttons to relieve any stored pressure. Also move the joystick into all positions, if that applies, to also relieve any pressure.
The second culprit in these situations is heat buildup in the attachment system. But that shouldn't be the case from what you describe. I'd rather say you've released the hoses with a "load" on the attachment side.
I gotcha.
Tractor off, then run position.
Flick the 3rd function a few times with tractor off.
Move joystick all around,
then done.
I can do that. I simply thought turning the tractor off would be enough. I'll see how this works. I was hoping it'd be just like an air line and it'd be quick on and off. Kind of sucks to have to do this each time, but it could be worse I guess.
Thanks man.
   / Third Functions Hydraulic Fittings Difficult to Engage #4
When I have that problem it is always two reasons. Either I forgot to wiggle the valves to relieve pressure on the tractor side connectors, or I left the attachment in a position where it is pressurizing the attachment side connectors.
   / Third Functions Hydraulic Fittings Difficult to Engage #5
I just got a Waite tool to depressurize the lines & it works as advertised. Ken's Bolt on Grab Hooks <<Hydraulic Tools>>
Turn the machine off & actuate the valves to relieve teactor pressure. Impliment side is often harder. If you put impliments away cold then it warms up the fluid expands a bit & pressurized the lines. That pressure pushes the poppets to stay shut & not let you connect things.
   / Third Functions Hydraulic Fittings Difficult to Engage #7
I have to turn the machine off and hit the third function buttons as stated above. I don’t move the joystick but I guess you could. I store the couplings on the blade connected to each other so I know that side won’t build pressure. Plus it keeps them clean.
   / Third Functions Hydraulic Fittings Difficult to Engage #8
Connecting them together does nothing to prevent pressure buildup due to heat. It's effective to keep them clean. That's about all.
   / Third Functions Hydraulic Fittings Difficult to Engage #9
Neve said anything about heat buildup.
But heat buildup on the implement side isn’t going to prevent coupling and uncoupling......their’s no heat being generated!!! You are slipping out of that armchair!
If the implement side is left uncoupled any settling, moving etc can cause pressure to build in the implement. It’s good and standard practice to recouple disconnected implements when disconnected from the machine.
   / Third Functions Hydraulic Fittings Difficult to Engage #10
... heat buildup on the implement side isn't going to prevent coupling and uncoupling......there's no heat being 'generated'!!! You are slipping out of that armchair!
If the implement side is left uncoupled any settling, moving etc can cause pressure to build in the implement. It's good and standard practice to re-couple disconnected implements when disconnected from the machine.
Reconnecting a hydraulic attachment that was parked on a cooler day means it's bound to have internal pressure without heat being generated.
Wobbling the joystick with the engine off makes connecting easier from the tractor side, but doesn't do piddly diddly on a warm Spring day when you go to hook up the grapple you parked in November. The tool Ken sells is superb if you don't want to make your own.
2015 Peterbilt 348 Dump Truck (A55973)
2015 Peterbilt 348...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
John Deere 1025R (A53317)
John Deere 1025R...
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
LIGHT TOWER (A56857)
