Snow Blower Frustration!
/ Snow Blower Frustration! #1
RidgeHiker
Gold Member
Upper California Mountains
Kioti DK5010 with KL5510 Loader & 72" Bucket. Kawasaki Mule Pro MX SE with 66" snow plow.
I have a 72" Woodmaxx snow blower on my 50 hp Kioti. Just broke another shear bolt. I have used regular snow blowers for years but this is my first tractor snowblower and do not know if I just do not understand it's capabilities or is there some other issue. Another way of asking is it me or the snow blower (or both)?
We have about 14" of new snow, not real heavy nor light. About 12"-16". Last night I hand shoveled out the entry area to my house and piled it into the driveway area. Maybe 2.5" high at peak. Pile was somewhat compressed from shoveling and sitting. Probably 1/2 the snow blower width was into it and rest into untouched snow. Shear pin died. Snow was packed into the auger blades and the impeller. Not like concrete but in there. I assume either I am expecting more out of the blower than is realistic or shear pins are too weak though I am using recommended ones, grade 5.
Feedback from more experienced users would be much appreciated. Thanks in advance for your assistance. Going to go out now and replace the bolt.
/ Snow Blower Frustration! #2
Sounds like the shear pins are doing their job. The only thing that can cause issues on a new (properly functioning- no internal binding etc) blower is improper driveshaft length or angle. With the machine off and PTO in neutral does everything spin freely- both on the ground and up 6” or so.
If that’s not the case...time to slow down
/ Snow Blower Frustration! #3
Which shear bolt, the PTO one, or the auger one?
Any pictures of the sheared bolt pieces?
Aaron Z
Couple other elements to mention. Love the tractor but would like to have a lower low range 1st gear. Probably would work better if I could go a little slower. Also, noticed that the PTO shaft is at least some times rubbing on the bottom corner of the upper horizontal bar of the quick attach. There is a couple inches clearance with it sitting on the ground now but is either bouncing or pushing together. I have adjusted the upper 3 point arm to create a little more space. Will see how that works.
/ Snow Blower Frustration! #5
This happens more often early in the season as snow sticks to warm metal, then freezes to it. Then, snow continues to stick to the rough surface until it plugs. Try spraying the inside of the blower with your favorite cooking spray or lube.
/ Snow Blower Frustration! #6
I have a 72" Woodmaxx snow blower on my 50 hp Kioti. . . . I assume either I am expecting more out of the blower than is realistic or shear pins are too weak though I am using recommended ones, grade 5.
Be thankful the shear pins are failing rather than something more expensive.
Does the Woodmax owner's manual specify an SAE size, grade 5 bolt? I Googled "Woodmax snowblower shear pins; Woodmax sells M6 x 35mm auger shear bolts, but does not mention the grade or show the face of the bolt head. The PTO shear bolts are non-standard with no specs.
My Italian Goldoni snowblower (10 HP) uses M6 grade 12.9 (176,900psi) shear bolts; my American Lorenz (max 40 HP) uses 1/4-20 grade 5 (120,000psi) shear bolts. (Grade 8 is 150,000psi.). The M6 bolts shear at a spot closer to the axis of the shaft than the 1/4" bolts, and I trust the engineers knew what they were doing. Https://www.engineeringtoolbox.com/steel-bolts-sae-grades-d_1426.html gives the specs for SAE bolts and a link to metric bolts.
Once you have the initial pass, you can adjust the input volume/weight of snow to ground speed by taking less than a full width pass. For the initial pass you may have to advance, stop to let the blower clear itself, and then advance again. Experience will teach you.
/ Snow Blower Frustration! #7
Post #3 has a screenshot of the shear bolt page in the manual. They call for a standard 2.25" long 5/16" diameter grade 5 fine thread bolt for the PTO shear pin.
Aaron Z
/ Snow Blower Frustration! #8
If the lower links are not fully extended(if possible) the propeller shaft will be shorter and can rub on the quick hitch cross member.
/ Snow Blower Frustration! #9
I just went back and enlarged aczian's attachment (comment #3). On page 24 the caption on the lower left picture states there are six 1/4" holes in the flanges on the augers. The "note" states the machine comes with two M6 grade 8.8 bolts [116000 psi so grade 5 (120000 psi) for practical purposes] but these may be substituted with two or three "1/4" x 18 x 1-1/2" bolts". One-quarter inch = 6.3 mm so grade 5 1/4" bolts would be stronger than grade 8.8 M6 bolts; 3 of them would obviously be stronger than the 2 original bolts. SAE 1/4" bolts are usually 20 TPI (coarse) or 28 TPI (fine); 5/16" bolts are 18 TPI (coarse). This may be a typo, but that and the lack of a grade spec for the substitution gives me pause. You might e-mail Woodmax for confirmation and to have something in hand if there is a warranty issue.
/ Snow Blower Frustration! #10
Good catch Captain Dirty, I suspect that someone copied the PTO shear pin spec to the auger shear pin spec and just changed the bolt size to 1/4".
Aaron Z
It is the shear bolt on the PTO shaft.
Not sure how good the angles are set. It is hard to picture how adjusting the height of the top link changes things. Have it set on the high bolt on the tractor side. Seems like there is an issue with keeping the blower more level so the back blade edge does not dig in to the ground and maintaining enough space between the PTO shaft and the upper bar of the quick attach.
Did better this afternoon after putting in new bolt. I cleared the berm from the snow plows at the front of my driveway with the blower but hit it in layers rather than just driving in to it. Shear bolt survived.
I will check that tomorrow but I do not think they adjust in and out. Just have bolt settings for up and down.
It is not the auger shear bolts but the PTO shaft bolt. Pretty confident that I have the correct grade and diameter because they recommended different grades online and in the manual so had to verify what was correct.
Aaron Z
Shear bolt pieces lost in the snow. In the past the cuts looked fairly clean if I recall from last season.
Also discovered my auxiliary led lights are not working when it started getting dark. More to figure out tomorrow. Also need to finish moving snow around.
/ Snow Blower Frustration! #16
I have a mile long, gravel driveway. I used a 3-point mount, PTO driven blower on my previous tractor. The first time I would clear the driveway - always blow a couple shear bolts. Large rocks I had not cleared, chunks of limbs fallen off the pine trees, chunks of ice - - you name it. It was ALWAYS a given. The remainder of the winter - maybe one more shear bolt.
If snow is packing into the blower - you are going too fast OR the snow is too wet or a little of both.
/ Snow Blower Frustration! #17
"If snow is packing into the blower - you are going too fast OR the snow is too wet or a little of both. "
What I did this year is to form a HD plastic liner for my chute and it worked fine, no clogging after the first season snowfall.
Now today we have4 inches of 'snowman' snow so it will be a real test.
So you are thinking that it clogs from the chute down?
/ Snow Blower Frustration! #19
That can be one cause. Does the tractor have an electro hydraulic PTO or standard PTO? At full RPMs the electro hydraulic PTO will gradually start the PTO shaft, but a standard PTO will jerk that PTO shaft to start at full RPMs; this will weaken and break the shear pins on the PTO shaft. A lot people do not realize this, so if you do not know the type of PTO you have, turn PTO on at low RPMs and then rev up to full full RPMs and then attack the snow. For wet snow, as others have stated, go as slow as possible so you do not clog the chute. Worst case spay the chute and fan with fluid film or some kind of oil; even PAM will work. Good luck!
/ Snow Blower Frustration! #20
Yes!
I noticed that many chutes are tapered.
By tapering the velocity is increased to get a further toss.
Tapering chokes the flow and creates clumps, ergo clogs, worst with wet snow but just fine with fluffy light stuff.
In other words it compacts the snow and that creating that clog.
LOL, if U can easily make a snowball expect clogging!
Now after yesterday's 4-5 of 'snowman snow' I have proven my theory.
No clogs in 2 hours of blowing wet 'snowball' snow.
Peterbilt 377 Semi-Truck (A63118)
Peterbilt 377...
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
UNUSED ATS ACE80-80 GALLON ELEC. AIR COMPRESSOR (A62131)
UNUSED ATS...
UNUSED WOLVERINE DB-15-84W 84" HYD PUSHER BLADE (A62131)
UNUSED WOLVERINE...
4 Shelf Rolling Cart 6ft x 3ft (A61166)
4 Shelf Rolling...
2005 INGERSOLL-RAND WL-350 WHEEL LOADER (A62129)
2005...
