My Senior design project - a "Swamp Thing" tracked vehicle clone
   / My Senior design project - a "Swamp Thing" tracked vehicle clone
OK, I cleaned it up a bit...
JK... :ashamed:
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #253
I had some brake lines made up and installed them. I will fill them, bleed them and try them out soon. Working on the tracks and front bumper next.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #255
From what I have seen your project is not 'thing' but rather a work of art.
Very nice!
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #256
Garauld is doing a nice job on it. Same as I'd be doing if it was my project...
Now this is what they call a bumper: :dance1:
I also made up some track bars:
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #258
Hi Garauld, great build you have going here. I signed up to this forum just to follow along!
I am curious about your brake steering system, especially since there was some mention of welding your differential spider gears.
Great work!
Hi Carbon - thanks for the kudos. It's a fun build. In reference to your curiosity there is a discussion about this subject early in the thread. Another reader noted that spider gears are not designed to handle this duty (which I agree with) and should be welded up. There are two ramifications of this: 1) I don't have to lock the other axle somehow (a good thing) as the Echo uses an open differential in the transmission, 2) the overall speed of the vehicle is reduced by 2 (not so good). I now calculate the top speed to be about 18 mph at 6000 rpm.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #260
Ok so there are two differentials in your drivetrain; the one in the echo transmission which would have driven the front wheels since its a transversely mounted engine, and then you are connecting that transmission to a driveshaft to power your Rav-4 differential with the brake-steer system, right?
So the transmission differential is the one you are welding up then?
2022 Ford Explorer 4WD SUV (A55758)
2022 Ford Explorer...
2017 Ford F-350 12ft Stakebody Flatbed Truck (A55788)
2017 Ford F-350...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2015 International 4400 SBA Gap Vac Truck (A53117)
2015 International...
2011 Toyota Camry Sedan (A55758)
2011 Toyota Camry...
Quick Coupler (A53316)
