WinterDeere
Super Star Member
- Joined
- Sep 6, 2011
- Messages
- 14,675
- Location
- Rural 'burbs, north of Philly
- Tractor
- John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
This is a little unusual. My 3-point is creeping down, but this is not the usual "bleed down" we often see, measured on a stopped engine. I mean I raise an implement, and as I'm driving it lowers itslelf, corresponding to the control lever creeping from the raised to the lowered position. If I push the lever back to a more raised position, the machine lifts the implement with no trouble. If I shut off the tractor, the machine keeps the implement raised with minimal bleed-down. But with the engine running the lever always moves and the implement always lowers.
This just started last week. Prior to that I had the hydraulic line crack that runs from my primary pump to the priority flow divider, and lost at least a half gallon of hydro fluid before realizing I was leaking. I did not lose enough fluid to have any issues with functionality, and promptly replaced the line. I will be looking to see if I accidentally loosened anything in the process of getting at that line, and failed to re-tighten it, but I don't expect I'll find anything.
What would cause this symptom? I'm not seeing anything about this in the technical manual for this machine. Tractor is a Deere 855.
