Ever buy a toaster?
/ Ever buy a toaster? #41
If you can'f find it, may I suggest you make it. One of the best thingsI ever got (from my VISA points) was a vaccume carafe coffee maker. No more burned coffee or good to the last drop with a fly in it!
/ Ever buy a toaster? #42
It will never be as good as the "good 'ol days". We were given a two slice Kenmore toaster for our wedding in 1965. We still have/use that toaster and it works great.
/ Ever buy a toaster? #43
Our $19.99 2 slice toaster from Bed, Bath and Beyond is only a little over 4 years old, but is the best one I've ever used. It has the wide openings that will accommodate "Texas toast" (thick stuff) and has settings for "Bagel", "Reheat", and "Defrost" as well as a dial for toasting time. I've never turned that dial more than halfway because I do believe it could overheat a piece of bread enough to possibly start a fire.:laughing:
/ Ever buy a toaster? #44
Wonder how much that toaster would cost if made in an American factory. If it was made in Canada, it wouldn't work for starters.
/ Ever buy a toaster? #45
I've got a basic 4 bay Sunbeam that I got at Walmart 13 or 14 years ago, been a real good toaster. I had to take it apart and clean the hold coil on one side as it wouldn't stay down, but that's what I would consider routine maintenance. It only sees dry bread, as gooey stuff is the number one killer of toasters. I have a toaster oven that I use a lot, it gets the cheese sammiches and other melty stuff. Being a breakfast for dinner type, toast is a regular fare here.
/ Ever buy a toaster? #46
I was gifted one of these, it works great, and looks cool too!!
Chicago Bears Toaster - Silver
/ Ever buy a toaster? #47
I remember my parents used to get small appliances using "green stamps" in the mid 60s when we lived in New Jersey.
/ Ever buy a toaster? #48
Yup...."S&H green stamps"....remember them well.
/ Ever buy a toaster? #49
Boy did we! . . . got them for everything gas, food . . . and collect enough you could get something really nice.
/ Ever buy a toaster? #50
I have two percolators; one electric, the other a stove top that I use when hunting. Sometimes though it's nice to stop and get another cup. All that I want is coffee, save the Starbucks and all of the other additives for somebody else. Yesterday I went to the (in)convenience store where they just installed these new, fancy machines which will grind the coffee and brew it while you watch. My palate just isn't sensitive enough to appreciate it... all that coffee needs to be is black and hot.
/ Ever buy a toaster? #52
:thumbsup:
That looks like the syrup used for vending machine coffee years ago.
/ Ever buy a toaster? #53
After reading this thread I had to go look at what brand mine actually is ..... and the most blatant marking was actually a fairly large Walmart stamped on the information plate on the bottom. Not sure they sell it any more, but it's fairly decent 4 slice (thick enough for half bagel in each slot) that's all metal body.
Though more and more I find myself buying small kitchen appliances and smallwares (chef's knives, ladles, etc) from commericial suppliers (tend to use Webstaraunt a lot) .....by the way the large metal cafeteria-style warming pans also work well as oil catch pans (and last I looked were actually cheaper per volume than oil drain pans marketed to mechanics).
/ Ever buy a toaster? #55
They say a watched pot never boils. Does a watched toaster ever pop up? Seems I either have to flick the lever or turn away to do something else.
Took it apart the other day whilst I was smoking up some bacon. The little bugger has a motor in it that cranks the toast up and down. Seemed clean. I tweaked a rod that slips into an inductive pickup. We'll see if that helps. Just wish it had a longer slot. By then Tesla will have a toaster on the market.....
/ Ever buy a toaster? #57
Acetylene torch. Kitchen model. You could print "TBN" on any sized bread, muffin, loaf or waffle.
Muhammad should be watching this thread. A TBN toaster to go with the ever successful TBN coffee mugs ;)
