sodamo
Super Star Member
- Joined
- May 20, 2004
- Messages
- 18,420
- Location
- Big Island, HI
- Tractor
- Bobcat CT4545 LS XR4140H (Mine) BX2380 (wife’s)
Mostly
Hope is to finish tomorrow, but installer blocked 3 days just in case. Tomorrow will be more technical, making sure the hookup is what I envisioned and works. This is going to be a rather unique system. My primary battery backup will be my diesel generator that runs chargers to just charge the batteries, no useable AC except right at generator. This will be an autostart system based on selectable parameters, most likely battery voltage.
My propane generator will be backup to this and connected to the Radian systems inverter/chargers. It too will be based on autostart parameters, but only operate if primary is in failure mode. Of course, I could change parameters and make this primary, but hope not to.
As for solar panels, the feeds come down the grey conduit between my distribution panel and and 1st Radian on left. There are 4 feeds from 14kw of panels. Each feed will connect to one of the black charge controllers via breakers.
