Good morning!!!!
   / Good morning!!!! #102,321
We got our Sleep Number Bed about 2 years ago. We love it. Good luck.
We bought our first Sleep Number bed more than 30 years ago and after more than 20 years, my wife talked me into buying a new one, but the wrong one. It's not really bad; just not as good as the old model "5000" which naturally is no longer made. So today the one we've had for 6 years, and that my wife liked more than I did, was replaced. We had a new one installed in our bedroom and moved the 6 year old one into the guest bedroom. I've no doubt our granddaughter will love playing with it.:laughing:
   / Good morning!!!! #102,322
We had our king size sleep number for many years, replaced it with new one thinking the old one would make good guest bed, but life changed and no guest room, gave the old sleep number bed to one of our daughters.. she ordered replacement foam inserts and it is good as new. We even put one in travel trailer. I have really appreciated it with my back issues. I can vary it as needed to be comfortable.
The last 24 hours has been a bit of fun I must say on the job transition.. my coworkers that are going to be taking over my old role have been notified by manager. They have both called now and expressed their disbelief, it would not surprise me to see one or both of them changing roles in next few months.
The other opportunity that presented itself was interesting enough that I have a meeting scheduled with that manager end of the week to see if it is something I would like to do. It is currently a small team and 3/4 of them are folks I have enjoyed working with in the past. I really think it would be a good fit, but will have to see if the manager and I get along, if he believes his folks that highly recommend me. I certainly have more spring in my step now than I did 2 months ago.
Praying that the solar changes David is working on today go well and no issues.
Stay safe, prayers for those in need.
   / Good morning!!!! #102,323
The Meyer Lemons (20 on the bush) and the hundreds of Kumquats and chickens survived the freeze and will soon be ready to harvest. (except the chickens they are still a little too hard)
The next two picks are the FrieWise clearing we did this morning and the CA mulcher was right behind us mulching all the limbs.
Eric do you have a boom on your FEL to pick up your octagon or how are you planing on picking it up without it hitting the hood?
Our garden's JD has been running on a 1/4 tank of diesel all Month so I opened up the tank and looked inside. It was bone dry. I put a note for the other tractor drivers to be sure to put fuel in it before running it and This evening, magically (like DisneyLand) 10 gallons of diesel appeared next to the tractor.
David new truck new power system you are ready for some trouble-free years.
   / Good morning!!!! #102,324
View attachment 629375View attachment 629376View attachment 629377
The next two picks are the FrieWise clearing we did this morning and the CA mulched was right behind us mulching all the limbs.
Try putting your chickens in your InstantPot. Poultry setting for 5 hours and natural pressure release.
   / Good morning!!!! #102,325
I’ve an idea that might help Eric lift his tank top. Titan builds an SSQA plate with a 3-point hitch on front side.
Skidsteer 3 Point Attachment Adapter Skid Steer trailer hitch front loader case https://www.amazon.com/dp/B008HS6KMO/ref=cm_sw_r_cp_api_i_2Vj1Db6ENYMWA
I’m ordering one soon, to allow me to put my 8’ HD 3-point Boom Pole on the FEL. I’d also use it to put my 84” landscape rake, on the front, to pull brush out from under trees.
   / Good morning!!!! #102,326
Got the 3 missing block added. Hope to try it this weekend.
I suspect the metal ring will rust pretty quick. The instructions actually said to not get it wet, wipe it off and store inside. I should of went to a metal fabrication place and had them weld me up a heavy duty ring.
   / Good morning!!!! #102,327
I'd just use it and ... every so often, spray the top, horizontal part, with some hi-temp black spray paint. I'm assuming you can lift it out?
http://www.walmart.com/ip/Rust-Oleum-High-Heat-Flat-Spray-Paint/17203457
   / Good morning!!!! #102,328
2 semi truck rims welded together make a great fire pit lots of steel.
   / Good morning!!!! #102,329
Pretty full, long day.
This was starting point
Removal got us here
Ended here for the day
Made a few adjustments along the way.
Still alot to due, but quite pleased. Installer remarked how he was enjoying working together. Already making plans this is a showcase endeavor.
Honda EU7000 doing a great job keeping us powered
   / Good morning!!!! #102,330
Good evening all. 42F this morning, clear sky, near calm wind. Moderate wind day, sky stayed mostly clear, and high temp was 79F. Slow start to day, had to take Scooter back home, then DOD meeting recap, nap, then bike ride and then wife decided not to go shopping, pickings are getting slim around here:eek:
Roy glad trip to work was non event.
Eric nice progress, will there be install pics?
Bird let us know how the new sleep # works out, inquiring minds want to know.
RNG including blurred pic of weld, gusset added for strength, longer seat post with more engagement below weld. Bike rides fine, ridden far enough chain needs a clean and lube before Saturday. Good luck with the gravel hauler.
Randy sorry for your loss.
Drew stew sounds good.
David neat pics, do you expect to finish tomorrow? Solar panels go through the inverters as well?
prayers for all
2007 Capacity TJ6500T Wet Kit T/A Yard Dog Toter Truck (A55973)
2007 Capacity...
WBrock Meyer 2000S 70'x12' 2000 BPH Grain Dryer W/Legs&Mill Discharge Sylo,Controller is included (A57148)
WBrock Meyer 2000S...
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
2016 VOLVO VNL780 SLEEPER (A59575)
2016 VOLVO VNL780...
2006 Dodge Ram Pickup (A56858)
2006 Dodge Ram...
