Model Advice
/ Model Advice
TSC has a similar unit rated to 1000lbs. Material looks same size and thickness. Difference is welded vs bolted so I wonder if quality non-chinesium bolts would be enough
/ Model Advice #183
I bet if I put it together with grade 8 hardware and put an angle brace from the top to the end of the forks I'd get enough capacity for my 66 gallon water tank....
I bet without all that you can hold that tank.
/ Model Advice #185
Rear forks as the basis for carrying a watering or spray tank?
That AgriSupply rear forks unit is rated 500 lbs.
Here's one I welded up from scrap, a phone relay rack and bedframe angle. I later ground down some crude parts and painted it. Norm would be proud of me! :) If you have a welder it would be easy to fabricate something similar.
I've used this since 2007 without anything bending or breaking, often at 500 lb total weight of the forks, platform, and load, which is all the little YM186D can lift. When I used it on the YM240, three garbage cans 90% full of water was the limit of what that tractor could lift.
Rear attachments that I've built fit on the qhitch directly instead of having pins and clips. This forks assembly is light enough to pick up and carry around. The forks from Agrisupply look heavier and are likely stronger - but this capacity matches my actual use.
70566d1171849399-pallet-forks-rear-3-pt-p1050892r-jpg
More photos:
Testing it the day I built it, lifting the 450 lb box blade with all the weight halfway out toward the end of the forks.
https://www.tractorbynet.com/forums...71849409-pallet-forks-rear-3-pt-p1050890r-jpg
Carrying water. Three 30 gallon cans. I filled a fourth can but couldn't lift it. That didn't hurt the forks.
https://www.tractorbynet.com/forums...4523073-3-pt-carryall-p00069rwateronforks-jpg
Original platform for forks. Last week I used a larger version of this to carry ladders and bring in apples we picked in the orchard.
https://www.tractorbynet.com/forums...37-rear-forks-p1640840rforks-platformforq-jpg
Forks are useful all the time. Portable mulch bin.
https://www.tractorbynet.com/forums...20291604-chipper-p1640058rhfshredderinuse-jpg
(INOP) 1991 INTERNATIONAL 4900 6X4 DUMP TRUCK (A62130)
(INOP) 1991...
2018 Freightliner M2 106 Single Axle Dump Truck, VIN # 1FVACXFC4JHJM9637 (A61165)
2018 Freightliner...
2021 John Deere W48R Walk Behind Zero Turn (A63116)
2021 John Deere...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63118)
2023 Unverferth...
2020 Broyhill Load and Pack TD3.6 Mini Articulated Garbage Truck (A61568)
2020 Broyhill Load...
2024 Kubota SVL97-2, PIN: KBCZ064CJN1J72104 (A61166)
2024 Kubota...
