massey 35 differentail oil
/ massey 35 differentail oil #1
jiminpa
northwest pa
massy 35 diesel kubota l3400
what oil do I use? gonna change it soon, but I don't think mineral oil is still around.it's a 1962 model.
/ massey 35 differentail oil #2
I have a Massey 245 and I am pretty sure I just put the same fluid as my other tractors. I think I had Deere Hy Gard on hand at the time.
/ massey 35 differentail oil #3
IIRC, that is common with the transmission fluid.
I would use a decent generic hydraulic fluid (unless you will be swapping hydraulic powered implements with a newer tractor, then get whatever that needs).
Aaron Z
it has a "Bull" hose on it, can lift but gravity lowers it! not a 2 line system. never used it.
found it! tsc traveler all mineral sae 90. sku 80660099
/ massey 35 differentail oil #6
I would use a more modern oil if you are planning on using it in the winter. That should be better for cold starts.
Aaron Z
went with the mineral oil type. something about my tractor has brass gearing and the modern fluid might damage it. anyway my 3pt will stay up now, no sneaking down!
