Saw help
/ Saw help #1
Barnbuilder
Gold Member
Waxhaw, NC
Bobcat A300, Kubota F3680, JCB 212S sold
My Husqvarna 365 is 21 years old. Always been good till now. Cutting some trees for a customer when it ran out of fuel. Filled it went to finish and saw would only run wide open, if it tries to idle it dies. Have to choke to start and same thing. Tried different gas no change. Obviously it gets fuel or it wouldn't run wide open. So filter is good. When you return to idle it sounds like a saw does when it runs out of fuel. Is it sucking air?
Any suggestions. I hate to take it to a shop.
/ Saw help
/ Saw help #3
Check the timing. It may be old enough it still has points and timing and stuff like that.
/ Saw help #4
This sounds like possibly a faulty (split or cracked) impulse line...it's similar to the fuel line but harder to get to (at least on a Stihl)...
/ Saw help
I tried low idle adjustment screw with no luck. If I idle up it will run but it's too fast.
/ Saw help
How do I check the timing?
/ Saw help #8
check all the fuel lines, doesn't take much of a crack to cause a roblem
/ Saw help
I cant pull the impulse line from crankcase tube so I'm guessing its ok. I know I replaced fuel line a few years ago.
Anyone changed over to a 52mm big bore kit?
/ Saw help #10
Sounds like it has an air leak. Often that's from a worn crank seal. Many of those can be replaced without splitting the cases.
/ Saw help #12
The quality of aftermarket cylinders range from not bad to complete horror show with nasty ports and bad port timing. Before buying I'd research who makes good cylinders for your saw. arborsite's chainsaw forum is one place for that.
/ Saw help
There's an OEM kit on Ebay. Is there any way to check the seals?
/ Saw help #14
First I would check the obvious like others have said, loose carb, impulse line, then have a pressure/vacuum test done. The entire crankcase should be air tight to operate correctly. You plug the intake and exhaust and subject the case with P/V and it should hold. If not, a case leak, seal leak would show up.
/ Saw help
Carb is tight and impulse line looks good as does everything else.
/ Saw help #16
Stuff can look good and still leak air. Sometimes there's oil residue around a leaking crank seal that gives it away. High idle and needing the choke to start are classic air leak symptoms. While it may run WFO with an air leak it's running lean... often lean enough to seize the piston.
/ Saw help #18
happening that quickly, and just by refilling the fuel, makes it most likely the carburetor got clogged!..
/ Saw help #19
Piece of crap on the low screw channel?
/ Saw help #20
Plugged fuel filter? You say it is good since it runs, but it might be straining to get fuel through it and only the choke and when WOT can force it to suck hard enough. How long since the filter was changed?
New/Unused AGROTK YC-26G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Caterpillar 289D (A64126)
Caterpillar 289D...
2001 Sea Breeze RV (A62613)
2001 Sea Breeze RV...
159120 (A60430)
159120 (A60430)
John Deere 410D Backhoe (A62679)
John Deere 410D...
