RTV900 replacement seat options
/ RTV900 replacement seat options #1
Jim Nelson
Fallbrook,Ca
Kubota B7800&B7510
I have a 2005 RTV 900 with real low hours and always kept covered but the seat, both cushion and back rest, is starting to go to pot. I think for its age this is to be expected and I can get both re-covered by a good upholsterer for $250-$300. This is based on another RTV1140 that I had to have both seat cushions redone @$150 each, the back rest is smaller so may be less. I really don't care for the stock seat as it is uncomfortable and anytime I'm on a side slope I have to brace myself even with seat belt.
I would like to go to a more comfortable seat with a better seat belt configuration and just wondered if any of you other RTV owners had found anything that worked for you and is reasonably priced.
Thanks Jim
/ RTV900 replacement seat options #2
I have a 2005 RTC 900 and bottom of seat started to tear. I use to just tape it up but I finally just bought a seat cover for it. Put some more tape on the tear and put the seat cover over it.
/ RTV900 replacement seat options #3
I had my mule seat reupholstered because the corner was cracked, but not happy with the job. He only folded over the corners and didn't use long enough staples. I could have done the same job!
Thanks for the reply. We have a local guy here who does a good job but he charges $150 per section and you still have the same uncomfortable seat,just no holes. It's usually only me in it so I was kind of thinking about a bucket type seat with more side support and a better seat belt system to help keep my round old body in the rig but haven't seen any that look like they would work in the crowded space.
/ RTV900 replacement seat options #5
My guy was a customer of mine and generally does really good old-school work. Does much work for transit authorities. Don't know how or why he did such a lousy job on this. You might be able to put in a couple of low back tractor or gator style seats, but would loose the possibility of carrying a cramped third party.
/ RTV900 replacement seat options #6
Thanks Jim
You might ask "seatwarehouse.com" if they have something.
Nice folks to buy from.
ATS 40 Gallon 2 Stage Air Compressor (A62679)
ATS 40 Gallon 2...
6ft Teakwood Indian (A65583)
6ft Teakwood...
1983 Mack DM492S Cab & Chassis (A62679)
1983 Mack DM492S...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
1998 Chevrolet C7500 Dump Truck (A62613)
1998 Chevrolet...
Pull Type Hay Stacker (A66408)
Pull Type Hay...
