Curl cylinder stalling engine
/ Curl cylinder stalling engine #1
treelackey
Ottawa, Canada
case ih 235
Currently having a problem with the curl cylinder on my tractor, when you retract the cylinder it will bog the engine to the point of stalling. Its just the curl fylinder, the lift cylinders work fine. Ive switched the lines and tried a different cylinder with the same results. Leads me to believe it is an issues with the valve. Any insights would be appreciated. Thanks
/ Curl cylinder stalling engine #2
I would look at your couplers, sounds like a bad one.
Already switched them for that cylinder with no change
/ Curl cylinder stalling engine #4
Can you move the bucket manually? If so the the piston may have come off the rod inside the cylinder.
Or, the spool in the valve casting has suffered a failure of some sort, but you should feel that when moving the joystick.
What equipment are we working on?
You cant move the cylinder manually. Its a homemade loader. I suspect its the spool either having a little piece of something in it or just being crap
/ Curl cylinder stalling engine #6
Could the push rod for the cylinder be bent.
When removed from the tractor and not connected to any hoses, if you cannot move the push rod, something serious is wrong.
Dave M7040
/ Curl cylinder stalling engine #7
You say it’s a homemade loader.......has it been like this from the start or is this something that recently started acting up?
My suspicion would be the loader valve is too small if you are seeing a pressure spike (using a guage on the pump outlet). but Just a WAG.
Just started doing this. My valve is rated for 15gpm while the pump puts out less. I havent put a pressure guage on it yet
/ Curl cylinder stalling engine #9
My old ford 851 has a paulson loader. It does this too. Do you have a pressure relief on the curl side too?
/ Curl cylinder stalling engine #11
Well that rules out my WAG (wild donkey guess)
You could rig up a temp hose direct from valve return to tank to rule out a restriction downstream of the valve:confused3:
/ Curl cylinder stalling engine #12
Sounds like you are deadheading the pump, either the relief is not operating (in circuit) or at the correct pressure, or the prime mover is under rated for the set pressure. First up check the relief pressure setting and check that it is functioning correctly.
/ Curl cylinder stalling engine #13
Generally if the piston comes off the rod oil will flow through the center hole in the piston and never build any pressure in the circuit or do any work.
/ Curl cylinder stalling engine #14
Maybe a chunk of packing/piston seal is creating a restriction in a fitting or in the valve core?
I removed the lines at the valve this morning and there was built up pressure so clearly something is blocking the return circuit in the valve. Ill be taking it apart to have a look this evening
/ Curl cylinder stalling engine #16
Can you take a picture for the valve for us?
Maybe you have the curl circuit plumbed on the work port of the valve. Some valves can be confusing with the check valves in the middle.
Heavy Duty D Ring Shackles (A61568)
Heavy Duty D Ring...
2016 Etnyre Falcon Live Bottom Trailer (A62613)
2016 Etnyre Falcon...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
UNUSED SDLANCH SDLGC100 ELECTRIC GOLF CART (A62130)
UNUSED SDLANCH...
2016 Chevrolet Silverado 1500 Pickup Truck (A61568)
2016 Chevrolet...
2014 Lincoln MKS Sedan (A61569)
2014 Lincoln MKS...
