Ballast Kioti CK2610HST and chains with R-4's
   / Kioti CK2610HST and chains with R-4's
They are OFA chains. I will check the exact model tomorrow.
   / Kioti CK2610HST and chains with R-4's #12
Thanks! I work in Center harbor so I can shoot over to Tamworth pretty easily to order/ pick up them up.
   / Kioti CK2610HST and chains with R-4's #13
I talked with the dealer I bought the tractor from and he tells me they are putting chains on that model with the R-4 tires. So, I went ahead and bought the Euro style chains from Windy Ridge Corp. in Tamworth, NH.
I don't believe there will be any room left, but I'll be trudging about as slow as that tractor will go anyway. My driveway is single lane, 400' long and if I rush, the fun will end too soon!
I will report back the results.
I have a 2610 w/ R4s and studded chains from Windy Ridge. No clearance problem at all. I put over 200 hours on it last winter blowing snow and running the tractor hard in all-terrain and did not have chains scrape or snag once. You'll be fine.
   / Kioti CK2610HST and chains with R-4's #14
I spoke with windy ridge yesterday afternoon and they suggested the eko8 or the easy on 5 if the clearance is tight. I’m going to measure the clearance to see what I have and shoot over there after work one day .
   / Kioti CK2610HST and chains with R-4's #15
I spoke with windy ridge yesterday afternoon and they suggested the eko8 or the easy on 5 if the clearance is tight. I知 going to measure the clearance to see what I have and shoot over there after work one day .
I run the eko8 on my setup (same as yours) and have no problem at all. And I like every bit of the traction they give me.
We got about 3+ inches of fairly dry snow here in the White Mountains which I'm driving over with no problem. It will make a good base. But Monday, the forecast is for wetter, icy mix.
I'm still waiting for my tractor delivery, maybe today. But I picked up the chains from Windy Ridge on Monday. Based on my measurements at the dealer and measuring the actual chains, I should be fine. The chains are OFA8 studded on the rears and a bit lighter, diamond pattern chain for the fronts, with the same stud type.
   / Kioti CK2610HST and chains with R-4's #17
Rears pictured.... View attachment 628583
I don't run any in the front and have never had a problem.
P.S. I'm up in Bartlett.
   / Kioti CK2610HST and chains with R-4's #18
Well it seems there痴 a lot of us Kioti 2610 folks in the area I知 in Sanbornton . I知 planning on going to windy ridge this afternoon and pick up the chains. I measured this morning and got 1-3/4 as the tightest clearance. This seems pretty tight , is this what you have for clearance? Also to double check I have the R-4痴 Size 15-19.5
   / Kioti CK2610HST and chains with R-4's #19
I have a CK3510 with filled R4's and clearance is tight. I had some old chains laying around that I used when I first got the tractor and they didn't fit well, I had to repeatedly adjust them, after one winter I had enough and picked up some TND Diamond Pattern chains from tirechain.com, they have a tensioner built in so it is easy to get them nice and tight, been using them for the last 4 winters without a problem. I have a steep driveway with a hairpin turn in it so I need chains on all four or I don't make it around the turn once we get some hard pack snow or any ice. I got the 2-link V Bar chains for the front, also from tirechain.com. With all four chains on I can (almost) drive like it is dry dirt.
   / Kioti CK2610HST and chains with R-4's #20
It's tight, but by no means too tight. As I mentioned previously, I put in about 150 hours in last winter blowing snow and pulling logs out of the woods with this setup (2610, loaded R4's, Eko8 chains on rear) and never threw a chain or had anything catch due to tight clearance. I was rough on them too, my farm is on the side of a mountain and all the driveways I do are steep and gravel. I just put them back on 3 nights ago, and again, no problems. I get what all your 2610ers are worried, but it really isn't an issue.
2017 Caterpillar 259D (A53317)
2017 Caterpillar...
UNUSED FUTURE POLYTHYLENE PROTECTION PAD (12 PCS) (A57193)
UNUSED FUTURE...
2022 John Deere 1025R (A53317)
2022 John Deere...
Mini Margaritaville Truck (A55853)
Mini...
2018 RoGator 1100C (A55315)
2018 RoGator 1100C...
2013 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2013 Freightliner...
