GENERATOR QUESTIONS FOR YOU EXPERT ELECTRICIANS
   / GENERATOR QUESTIONS FOR YOU EXPERT ELECTRICIANS #41
I saw something on wiring a zig-zag configuration on a MEPS 12 terminal type genset. It was not well explained. I am interested and will try and find something to make me understand it. Always interested in understanding how things work as opposed to just believing what I am told.
Zig-zag!! :eek:
I only heard of that configuration used as a grounding transformer.
I can get you through resistive grounding schemes, but if you're using zig-zag transformers for grounding, (or zig-zag gensets ??), that's beyond me!!
   / GENERATOR QUESTIONS FOR YOU EXPERT ELECTRICIANS #42
   / GENERATOR QUESTIONS FOR YOU EXPERT ELECTRICIANS #44
That video shows how to modify a 3ph only generator into single phase. The mep802 that i own has single and 3ph capability just by turning a switch. Its due to extra windings in the head.
   / GENERATOR QUESTIONS FOR YOU EXPERT ELECTRICIANS #45
I got a crazy generator.
It is a 4 cylinder gas/propane generator, liquid cooled, but only produces 3000 watts. However, this is the crazy part, it produces that power at either 1 or 3 phase depending on what you want. I know there are many 3 phase generators, but I have never seen one so small in Kw's that can have either.
...but the 3 phase kW/kVA rating is different than the 1ph kW/kVA rating....right?
   / GENERATOR QUESTIONS FOR YOU EXPERT ELECTRICIANS #46
So do MEPPS sets typically have more windings than a run of the mill 3 phase alternator? Not that I yet understand the phase implications.
On the smaller MEP gensets (like nyone has), they ran all the leads out to a reconnection box so it can run either single or 3 phase.
The one in the video, IIRC had the leads brought out, but the genset was only setup for 3 phase, so you could only load it to 60% capacity.
Yep, on your genset they ran all the leads out to the reconnection box so it can run either single or 3 phase. Most "civilian" gensets don't need that capability, so they save money by keeping those leads shorter and connecting them inside the generator head.
There was a thread on Steel Soldiers that went along with that video, I will see if I can find it.
Aaron Z
   / GENERATOR QUESTIONS FOR YOU EXPERT ELECTRICIANS #47
Of corse its rating is different not 1/3rd though.
   / GENERATOR QUESTIONS FOR YOU EXPERT ELECTRICIANS #48
Not if you reconnect the wires to the generator head, if you do that, you will have the same watts available for single phase as it had for 3 phase. That was the point of doing that, more capacity at 120/240 single phase.
Aaron Z
   / GENERATOR QUESTIONS FOR YOU EXPERT ELECTRICIANS #49
I'm still going to try and understand this. But wording is important. Because a generator CAN be switched from 3ph to single, does not necessarily mean it will work to full capacity. It might, but it also might not.
I am just thinking out loud, but maybe the extra windings are to supply different voltage. Because you usually only get 208 when running single phase, which they say is generally not a problem, but I would disagree. I want 120/240. That extra series winding on each phase would make perfect sense if that were the case, but would not address the derating factor.
   / GENERATOR QUESTIONS FOR YOU EXPERT ELECTRICIANS #50
208 is used all the time on 220/240 systems and is of no issue. A lot of apartments I worked on were supplied 3/0 to panels knowing everyone would have 208 volts. In the 100痴 of times I致e done this in over 35 years as an electrician I have had no issues. On average the only appliances using 208/240 in a residential panel are a/c, water heater, general heating and dryers. These are not effected by 208.
even if you rewire a 6 or 12 wire 3/0 to operate as single phase, you do get a loss in overall amperage available. Then again, I may be wrong Generator Phase Conversions: Electrical Conversion, Single Phase, Three Phase Power
It does get confusing.
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
2024 JOHN DEERE 6110M LOT NUMBER 56 (A53084)
2024 JOHN DEERE...
2015 Ford F-250 Liberator 3200 1.5 Ton Crane Service Truck (A55852)
2015 Ford F-250...
2017 Chevrolet Express 2500 Cargo Van (A55852)
2017 Chevrolet...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A55851)
1996 JLG Commander...
2008 KALMER 4X2 SPOTTER TRUCK (A51247)
2008 KALMER 4X2...
