3-Point Hitch RK55 3pt fine tune
   / RK55 3pt fine tune #1
jethroish
Member
Scottsburg, IN
RK55S, CC EX3200
I know there is an adjustment to control the lowering speed of 3pt implements, but...
Is there any adjustments to quicken the react time when raising? I use this tractor to work my horse arena. My hand is always on the 3pt lever to constantly adjust the arena tool (see profile pic) up and down to keep dirt as level as possible. When raising, it seems slow to react and then it will raise too much and not very smoothly.
Any tweeking or am I expecting too much? Will this smooth out/loosen up with time? I have used other tractors that are very smooth, but they also have expensive paint.
   / RK55 3pt fine tune #2
I know there is an adjustment to control the lowering speed of 3pt implements, but... When raising, it seems slow to react and then it will raise too much and not very smoothly.
Try running it at a little higher revs to move more fluid for lifting and adjust the know to lower at your desired speed. There is an adjustable positive-stop knob on mine (currently on the lowering end of the 3PH control). I have a similar setup on my NH that can be moved to the upper side to limit the lever's lift height. I haven't tried relocating it on my RK - maybe that will help too if it can be moved.
Usually working at 2000 rpm
   / RK55 3pt fine tune #4
Was hoping others might have jumped in by now...hmm...
I have never had a draft control before - never used one and only a surface knowledge of what it does - but I understand that it's for ground-engaging 3PH implements. Don't know if fiddling with that might help...or not...
   / RK55 3pt fine tune #5
I don't think Draft Control will help his situation. It is still relying on the lift speed of the system.
Top Link Draft Control senses the load on the top link to raise/lower the tool.
1. If the tool is too low it will create drag load and push forward on the top link. This push is sensed by the tractor's system and will slightly raise the load.
2. If the tool is too high it will not have drag load and pull rearward on the top link. This pull is sensed by the tractor's system and will slightly lower the load.
ovrszd,
You are correct. I need to be able to, essentially, not have any draft at all and control it all manually. That way I can keep the surface of my horse arena level. If the draft is allowed to work, the surface ends up rippled.
   / RK55 3pt fine tune #7
ovrszd,
I've never saw a way to speed up the lift of a 3pt. My old Ford 3910 has the ability to slow the hydraulics. Comes in handy if doing BB work. I have the valve wide open all the time, at it's fastest speed.
I say this with no malice. Practice makes perfect. Keep at it, you'll pick up the "touch". :)
Problem is when I try to raise the 3pt, it does not come up smoothly. When I pull the lever back a very small amount, it does nothing. When I pull back a little more, it ends up jumping 2 inches or more, all at once. Letting it back down, it lowers smoothly.
Makes it frustrating doing "fine grade work."
Don't get me wrong, I really like this tractor. This is the only slight complaint I would make.
   / RK55 3pt fine tune #9
Oh, I see. My Son's Kubota B3200 is like that.
In his tractor's case it has 1/4 inch valving. Idea being if you pull the lever toward lift it is supposed to lift 1/4" and stop. Let the lever back to center. Repeat. 1/4" lift each time.
Or if you want total lift you pull the lever all the way rearward and it lifts to it's max height.
Makes fine work very tedious. When he first got it he couldn't do smooth work at all. He's gotten much better.
Position Control 3pt puts the height of the arms at the same spot each time you move the lever to that particular position.
Easy way to tell the difference.
Is your lever spring loaded back to center? If so it's 1/4" valving.
Is your lever have a movement resistance built into it? In other words when you move it you feel a slight drag. And if you let go of the lever it stays exactly where you put it. If so it's Position Control.
Once we figure that out then we can better diagnose if there is a problem.
I was hoping other RK owners would chime in with some knowledgeable advice.
it is Position Control
Skid Steer 43" Disc Mulcher (New/Unused) (A59225)
Skid Steer 43"...
2013 Infiniti G37 Coupe (A54815)
2013 Infiniti G37...
2017 Nissan Titan (A55788)
2017 Nissan Titan...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2025 GIYI MULCHER SKID STEER ATTACHMENT (A58214)
2025 GIYI MULCHER...
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A56435)
2006 Heil Tanker...
