intermittent fuel problem
/ intermittent fuel problem #1
tom andrews
wa
nortrac 3500 dozer
Greetings, I have a Nortrac 3500, 30hp. The dozer abruptly shut down and would not restart, of course out in the boonies. I determined the transfer pump was pumping fuel thru the spin filter to the inlet of the injector pump. Nothing coming out of the injection pump. Two days later, I rechecked my process, now I was getting fuel out of injection pump. Hooked up lines to injectors, machine started, bled air and machine is running fine and sitting in shop. How can I check integrity of the injection pump, or am I overlooking something?
/ intermittent fuel problem #2
I'd put an inspection camera down into the fuel tank... you could have a biological growth (known as 'algae', but it's not). It'll look like fairy-floss (cotton candy) mixed with phlegm.
A major cause of intermittent diesel fuel problems.
/ intermittent fuel problem #3
I have personally witnessed diesel bugs bring a 14,000 HP diesel engine to it's knees, and subsequently $125,000 in fuel system repairs. They are very corrosive and can destroy injectors and injector pump plungers and barrels, not to mention steel fuel lines. I use this test kit periodically on my storage tank. https://www.amazon.com/Biobor-HUMBU...eywords=humbug+test+kit&qid=1572051131&sr=8-1 I think the first thing to do is determine if you do have a dose of the "bug" because that will direct the course of action.
Many articles have been written on this topic.
Microbial contamination of diesel fuel - Wikipedia
Here is one of my personal experiences with the slimy sludgy critters (the pink stuff is fuel).
/ intermittent fuel problem #4
WOW BOB.. I've NEVER seen a tank THAT BAD.!!
Tom, u do have a weird problem.. U prob. need to inspect the fuel AND TANK..
Its weird because u had NO FUEL & then the next day U HAD FUEL..
1 think I should mention.. the supply pump HAS TO pump enough fuel to fill the fuel gallery AND open the overflow valve..{prob. 25psi}
Does your have a hand primer on it..??
IF SO, run the hand primer until u hear it passing fuel thru the checkball return & back to the tank.. THEN try to start it..
IF it continues & your tank is clean.. u can contact me by clicking my screen name on the left hand side of the page.
I hope u find SOMETHING.. Good Luck.
/ intermittent fuel problem #5
There is another less expensive possibility, and that is there is something in the bottom of the tank that gets sucked onto the line line and block it until the sucction stops(engine died) then floats clear and you can restart and it will run perfectly until the obstruction gets sucked uver the fuel line again.
Take wagtails advice and put an inspection camera into the tank so you know one way or the other.
Thanks to all for the replies. Machine still starts and runs fine now, of course it is sitting in the shop, I'm reluctant to get back out in the timber with it again. But I'll definitely check the tank for obstructions. Maybe the supply pump is pumping, but not enough pressure as the pumpguy mentioned.
/ intermittent fuel problem #7
Don't know if I mentioned it before, but I too was stuck in the woods with bug issues once. That prompted me to install a fuel pressure gauge connected to my alarm system. There is a ball-check pressure regulating valve on the injection pump (every diesel engine in the world has some such valve). It maintains a nominal 22 psig fuel pressure in the injection pump fuel cavity and assures the plungers have adequate fuel under all conditions. Some are adjustable, others look like a ball is swaged into the banjo fitting. Corrosion from bugs has been known to cause the spring to fail and to cause pitting of the ball seat, lowering or shutting off the fuel pressure. I personally had to replace the lift pump because the valve seats were so badly pitted that it barely pumped fuel.
/ intermittent fuel problem #8
As a side note, these machines do not have a primary fuel filter per se, just the screen in the sediment bowl so this must be maintained intact and periodically inspected because they can catch some bugs.
As an over-kill precaution against any further fuel related interruptions to my seat time I installed an electric lift pump.
Note: My Mitsubishi excavator and Yanmar powered skid steer both use an electric lift pump instead of a mechanical one.
Thanks Bob, that was a ton of info. One can't go wrong with belt and suspenders.
Bob, an alarm system, what all do you monitor? The previous owner of my machine ran a tree branch up thru the oil filter, not watching oil pressure gauge ruined engine.
/ intermittent fuel problem #12
I monitor coolant temperature, oil pressure, and fuel pressure using mechanical Murphy ©Switchgages. The set points and contacts are easily adjusted through the gauge face. These are industrial quality gauges and priced accordingly. Some are available through Amazon, otherwise - U.S. Sales Distributors | FW Murphy Production Controls
/ intermittent fuel problem #13
Surely he knew these machines don't have a belly pan. He didn't know the machine or it's limitations, and wasn't operating it accordingly.
A big 10-4 on your previous thread. My machine since it died abruptly out in the boon docks now is very difficult to get started when its cold. Previously it started very easy even when quite cold. I have been bleeding the fuel system when I get it started to no avail. Is this a clue of what might have given me these headaches?
/ intermittent fuel problem #15
Do you get any smoke from the exhaust now when trying to start? Does your fuel injection pump oil now smell like diesel fuel? Have you tried using the glow plugs before you start? Once bled, the fuel system should not require further bleeding.
One other thing, did you replace the spin-on secondary fuel filter?
I have noticed that I seem to be getting more white smoke out of exhaust when cranking to start. I won't be able to smell the fuel injection pump oil as I have to be away from the machine for about a week. But on that subject, I checked the oil level on the pump, never saw anything in the owners manual about oil level in an injection pump, saw it on a post somewhere on this site, it was low, added oil to what I believe was the correct overflow plug, next time I got it started I had oil coming out of another overflow.?? I have been using the glow plugs for about 12 seconds. I changed spin on filter, and made sure I bled air that might have been introduced. Is the white smoke significant? Thanx Bob
/ intermittent fuel problem #17
Also make sure the fuel tank breathes, you need air to replace the fuel that is drawn from the tank.
Removing the filler cap is one easy test.
Every fuel tank has a screen just before the outlet.
Crud can block that screen and starve the engine.
Also the slightest leak in the injector inlet line can allow air and the injector pump can't suck air, only fuel.
/ intermittent fuel problem #18
White exhaust smoke in the absence of any coolant loss indicates unburned fuel, so if it was determined that you had diesel bugs that were undetected for some time, one or more of your injectors could be dribbling. These injectors are cheaper to replace than rebuild, but nominally cheaper yet to get pop tested if you have a diesel shop nearby.
There are specific resistance readings for glow plugs but for brevity your ammeter should show close to a full discharge when you have the glow plugs applied, anything less indicates failed or failing glow plugs. You may also have inadvertently knocked a glow plug wire loose while working on the engine.
2021 Wacker Neuson G25 Quiet Power 20kW Towable Generator (A64553)
2021 Wacker Neuson...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
PIPEHUNTER HYDRO EXCAVATION TRAILER (A65643)
PIPEHUNTER HYDRO...
2014 Freightliner 114SD T/A Dump Truck (A64556)
2014 Freightliner...
2016 JCB 3CX 4x4 Loader Backhoe (A64194)
2016 JCB 3CX 4x4...
2015 VOLVO L30GS WHEEL LOADER (A65053)
2015 VOLVO L30GS...
