How many plows do I need on a Bottom Plow?
   / How many plows do I need on a Bottom Plow? #11
Is there a rule of thumb to figure out when to use a one bottom plow vs. a 2 bottom, 5 bottom, 7 bottom, etc?
Here's a 55 hp tractor pulling a 3 pan in Peru (1st breaking ground pass) tractor weighs about 5400lb
SHANGAI NEW HOLLAND CUSCO PERU - YouTube
Have basically the same older model of the tractor in video and it pulled a 3 bottom plow in clay without problem
I think a 4 bottom would have been a good test though
   / How many plows do I need on a Bottom Plow? #12
I can pull a 2 bottom plow (14") with my 25 HP Kubota, but the single bottom plow does a much better job at plowing. It has to do with how it can roll rocks out of the ground.
Thanks for that demonstration.
I suppose I will need to rent the biggest tractor I can find. I知 going to prepare about 15 hectares, and want to do all the prep work as quick as possible, so the more bottom plows I can pull, the merrier. It痴 just going to be a question of what痴 available in my area for rent.
   / How many plows do I need on a Bottom Plow? #14
the current biggest tractor is the John Deere 9630. the big bud 747 was a limited run, and not made anymore. John Deere 963 Tractors for Sale | Machinery Pete
   / How many plows do I need on a Bottom Plow? #15
   / How many plows do I need on a Bottom Plow? #16
We have pretty heavy clay around our area. When we used to use "breaking plows" back in the 1980's, we pulled a 5-16 ( 5 bottom, 16 inch width each) behind our 100 hp tractor, and a 4-16 behind our 85 hp tractor. I currently use a 2-12 behind my 30 hp Kubota every couple of years on the garden spot.
Based on my limited experience, 20 "drawbar" horsepower per 16 inch bottom is about a minimum.
   / How many plows do I need on a Bottom Plow? #17
   / How many plows do I need on a Bottom Plow? #18
not if you rent it. he wants to rent the biggest he can find, and get the job done as quickly as possible. his words..
Where can you even rent a tractor that big? And assuming you could do your have any idea what rental and transport is going to cost? You’d be a lot more economical with a average size utility tractor and maybe a 5 bottom plow. You’d spend more time trying to move a huge tractor than doing the job with a smaller one.
   / How many plows do I need on a Bottom Plow? #19
The OP is in PERU.
   / How many plows do I need on a Bottom Plow? #20
The OP is in PERU.
yep, so who knows what the ground is like there, it may be a nightmare, and who knows what they have for rent there, it may be so rural that they have huge farms there!..
2025 GPS Trailer (A56858)
2025 GPS Trailer...
202482 (A54757)
202482 (A54757)
MURRAY PUSH MOWER (A55745)
MURRAY PUSH MOWER...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A56859)
2004 Fleetwood...
1969 Lincoln Continental Mark III (A56859)
1969 Lincoln...
UNUSED KJ 11' X 19' ALL - STEEL CARPORT (A52706)
UNUSED KJ 11' X...
