How many plows do I need on a Bottom Plow?
   / How many plows do I need on a Bottom Plow? #11
Is there a rule of thumb to figure out when to use a one bottom plow vs. a 2 bottom, 5 bottom, 7 bottom, etc?
Here's a 55 hp tractor pulling a 3 pan in Peru (1st breaking ground pass) tractor weighs about 5400lb
SHANGAI NEW HOLLAND CUSCO PERU - YouTube
Have basically the same older model of the tractor in video and it pulled a 3 bottom plow in clay without problem
I think a 4 bottom would have been a good test though
   / How many plows do I need on a Bottom Plow? #12
I can pull a 2 bottom plow (14") with my 25 HP Kubota, but the single bottom plow does a much better job at plowing. It has to do with how it can roll rocks out of the ground.
Thanks for that demonstration.
I suppose I will need to rent the biggest tractor I can find. I知 going to prepare about 15 hectares, and want to do all the prep work as quick as possible, so the more bottom plows I can pull, the merrier. It痴 just going to be a question of what痴 available in my area for rent.
   / How many plows do I need on a Bottom Plow? #14
the current biggest tractor is the John Deere 9630. the big bud 747 was a limited run, and not made anymore. John Deere 963 Tractors for Sale | Machinery Pete
   / How many plows do I need on a Bottom Plow? #15
   / How many plows do I need on a Bottom Plow? #16
We have pretty heavy clay around our area. When we used to use "breaking plows" back in the 1980's, we pulled a 5-16 ( 5 bottom, 16 inch width each) behind our 100 hp tractor, and a 4-16 behind our 85 hp tractor. I currently use a 2-12 behind my 30 hp Kubota every couple of years on the garden spot.
Based on my limited experience, 20 "drawbar" horsepower per 16 inch bottom is about a minimum.
   / How many plows do I need on a Bottom Plow? #17
   / How many plows do I need on a Bottom Plow? #18
not if you rent it. he wants to rent the biggest he can find, and get the job done as quickly as possible. his words..
Where can you even rent a tractor that big? And assuming you could do your have any idea what rental and transport is going to cost? You’d be a lot more economical with a average size utility tractor and maybe a 5 bottom plow. You’d spend more time trying to move a huge tractor than doing the job with a smaller one.
   / How many plows do I need on a Bottom Plow? #19
The OP is in PERU.
   / How many plows do I need on a Bottom Plow? #20
The OP is in PERU.
yep, so who knows what the ground is like there, it may be a nightmare, and who knows what they have for rent there, it may be so rural that they have huge farms there!..
2025 Wolverine SP-15-84W 84in Snow Pusher Skid Steer Attachment (A55973)
2025 Wolverine...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
2016 Peterbilt 389 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2016 Peterbilt 389...
1999 Volvo WG T/A Dump Truck (A55973)
1999 Volvo WG T/A...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2005 CHANDLER  500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
