I Still Hate My Tractor II
   / I Still Hate My Tractor II #371
Oh Oh
tractor split, valve cover off....
Engine trouble? or just setting the valve clearance while in there replacing a clutch.
   / I Still Hate My Tractor II #372
Be nice to know what was being repaired, but any repair is a good repair when you dont end up with extra bolts or parts when done............
Leaking oil out the clutch housing, typical driveshaft seal failure. I've beat this tractor relentlessly for 500 hours, done the fluids and filters too often but never expected this.
Looking for more power as long as engine is out. Not sure how to get it. Maybe timing, bigger nozzles and a little more boost. This machine needs like 80 hp to do a proper job for me, not 60. It's the most gutless tractor I've had to endure.
I'd love to find the update bulletin for the seal repair so I don't go through this again after 500 more hours. I really want a better machine but I'm stuck with this one because of the add-ons. Snowplow, chains, 3 remotes, front remote. Too much to give away on a trade.
Going to baseline the engine today to make sure the innards are ok after such abuse I've given the thing.
   / I Still Hate My Tractor II #374
   / I Still Hate My Tractor II #375
500 hr in 6 years, must mean I'm over due @1,100 hr in 12 years for a drive shaft seal failure, at least your tractor dont stick in gear.
   / I Still Hate My Tractor II #376
I had a bit over 1500 trouble free hours on my L5030 then traded it for a L5740HSTC and had a failure in under 200 hours, so it was fixed under warranty. The shop foreman said they had never experienced that, so he used mine to demonstrate the repair; said the new seal was better, so I guess I eill find out in time.
Only posting this in the event it helps in any way. See attachment in the following link. https://www.tractorbynet.com/forums/kubota-owning-operating/184150-l5030hst-lleaking-oil-weep-hole-post2208761.html#post2208761
Curious to learn what the baseline numbers are.
Thank-you for the pdf.
So my FWD shaft is bent and when I spin it the runout is about 1/16" which is quite a bit. I want to say maybe I bent it splitting the tractor but I have to say I was so careful it came straight apart very smoothly I just don't see how I could have bent the thing.
Motor has 2 cylinders with 8% leakdown and 2 with 40% leakdown so my plan changes. Pulled the head and the pan to find pistons are junk with the top ring land worn badly.
This is what happens when you over fuel and boost an engine not designed for it. The wastegate is set at 6.5 pounds (factory).
I noticed about 2 years ago the engine isn't silky smooth like it was when new, it kind of has a touch of a misfire. I was right. Glad I took it all the way down while it was apart for the seal fix.
Looks like I'll replace 4 pistons, rings and remove the turbo then sell it in the Spring because the power will be so bad. Rod bearings look like new.
   / I Still Hate My Tractor II #378
View attachment 626339View attachment 626340View attachment 626341View attachment 626342
So will you finally buy a tractor that has enough horsepower for your needs?
Aaron Z
   / I Still Hate My Tractor II #379
Wow really did wear the ring lands badly,
wonder if Kubota uses steel ring land inserts for the Turbo spec pistons?
   / I Still Hate My Tractor II #380
Aaron Z
Why in the world would he do that? If he did he couldn’t start a “ I still hate my tractor lll”
2024 CHEVROLET SILVERADO 2500 HD BED (A57880)
2024 CHEVROLET...
Heavy Duty Aluminum Service Truck Bed Rack (A55787)
Heavy Duty...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
2015 GENIE S-45 TELESCOPIC BOOM LIFT (A52709)
2015 GENIE S-45...
2006 International 4300 Altec TA50 50ft Material Handling Bucket Truck (A56858)
2006 International...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
