Reality check for this newbie. What do I really need? 15 acres, but no livestock.
/ Reality check for this newbie. What do I really need? 15 acres, but no livestock. #11
I have 3 acres and zero livestock. Even with my small amount of land, my personal opinion is "regular" mowing (not brush hogging) with a tractor is a waste of time. Ive pulled a fairly good sized finish mower behind my John Deere tractor and Ive also mowed with zero turn mower with a 61" deck. The zero turn will just tear the tractor up time wise and cut quality. If your just mowing - no need for a tractor. The mower you have will likely do it just as good, if not better.
.....but absence of live stock or needing to hay doesnt mean you wouldnt use a tractor. I have neither need and use my tractor almost daily. If your the "do it yourself" type guy, you will wonder how you ever existed without a tractor.
This week Ive used my tractor to:
move a 8x8 shed across my yard to a new location
level a high spot in my yard
spread 4 ton of gravel to patch holes and fill low spots in my driveway
drag/place a telephone pole I had across the ditch on my 3 acres (was there to keep people from driving thru it)
take a brush pile to the brush dump (its in town)
unload heavy items out of the back of a semi (my new toolboxes)
fix a few pieces of fence (used the backhoe to pull the old post out/used it to push the post back in place)
Ive owned my tractor for maybe a month, already have about 20 hours on it....not sure how I lived without it. Alot of these things WOULD have been done with manual labor or my truck and a chain....but the tractor does them easier with less effort on my part and usually in a safer way then how I was "getting by" in the past.
If your just gonna live there, mow and call people when stuff isnt to your liking to fix it - probably dont need a tractor.
Me, Id rather do stuff myself.....and usually that means I own alot of crap to get it done. Not saying one or the other is the right way.
/ Reality check for this newbie. What do I really need? 15 acres, but no livestock. #12
Well said and some good points. One Caveat to all of this and as I get older the cost benefit analysis has come into light and there also is things that just aren't worth my time. Im still young but when I was younger doing it myself was it, thought I saved money etc. And yeah something to be said about doing it yourself, do the way you want, and done right. But over the years I have figured out that sometimes doing it my self actually cost me more money or didnt save me any money. Example I bought a 10k zero turn at one point, although my lawn could have been mowed for right around 100 bucks a whack. I would have to mow that lawn for 10 years to break even on that machine, probably more by the time I figure in gas, oil, and maint.
Just something to think about
/ Reality check for this newbie. What do I really need? 15 acres, but no livestock. #13
A $10k zero turn is going to be a large 60/70in model and may even be diesel. Why do you need to mow that much area when it could be turned into hay/leased section/money. Zero turns cut so fast that inless time is money i dont see a real benifit of a 72in cut mower. They also scalp more than a smaller deck. I would aldo never buy a commercialy owned mower and you will be hard pressed to find a homeowner owned 60in mower.
/ Reality check for this newbie. What do I really need? 15 acres, but no livestock. #14
Think mine was on sale for something like 7 plus tax and tag. I did that with a small tile job once. Bought the tile saw, other tools etc. Could have had that small job done for cheaper or the same price as I bought all the crap for that now just sits. MY point was doing stuff yourself is not always cheaper.
/ Reality check for this newbie. What do I really need? 15 acres, but no livestock. #15
Lots of pros and cons to ownership of tools and material in order to do it yourself rather than contracting it all out. As for myself, I prefer to do most things myself if possible. Yes I have some tools that I likely will never use again like my tile saw that I bought when I put tile in to replace linoleum flooring in my previous house. The tile was free so the tile saw and some grouting tools were my only expenses other than the grout. I wouldn't do that today due to my bad knees.
One thing that folks that are retired should consider is your health benefit from the exercise gained from doing work yourself. If you are retired and dont keep busy doing "something" then you likely wont live long after retirement. I know personally of a few incidents and hear of lots more where the guy retires, becomes a couch potato and dies just a few short years after retirement.
I try to do a little something everyday in order to get outside and get some exercise. So far 10 years into retirement and all is still pretty good.
Lastly, you get the satisfaction of doing the job yourself. Not much satisfaction in hiring something done that you can do yourself.
Now as for a tractor or not, that is up to the OP as to whether he wants to do everything by hand OR use a tractor with FEL to lift, drag, dig, mow things(plus many other items that come up). Yes for sure a zero turn, or other lawn mower type, can mow your pasture if you do it regularly, but one may not want to mow a 5-10 acre pasture every 2 weeks when a tractor with bush hog will work just doing it twice a year. Letting it grow up for 4-6 months is good for the wildlife. Taking hay off regularly depletes the soil if you dont add back some fertilizer whereas leaving the clippings to rot keeps the soil fertile.
/ Reality check for this newbie. What do I really need? 15 acres, but no livestock. #16
Buy the tractor and enjoy using it. You will be amazed at how many projects you will find.
/ Reality check for this newbie. What do I really need? 15 acres, but no livestock. #17
This. You may not absolutely have to have a tractor, but if you do, you'll find plenty of uses, from maintaining a driveway, to moving brush, to using it for a skinning rack!
Lots of great info and insight here! Some have confirmed some of my suspicions about whether I'll need one or not. I'm not the most DIYer, but I also don't mind hard work either. I'd rather go out and clean up a dead tree myself than find someone to come do it for me.
I guess I could go out there and for the first year or so, hire out someone to cut the hay, get a feel for the land and jobs that it may require, and then meander to the tractor purchasing world.
Keep the good stuff coming, I love it!
/ Reality check for this newbie. What do I really need? 15 acres, but no livestock. #19
If you can restrain yourself after firing up your own tractor (few do) you could be will served by an < 25.4794 horsepower / 100 cubic inch, 2,700 pound bare weight tractor with 4-WD and a three (3) range HST transmission. Tractors < 25.4794 horsepower are exempt (for now) from strict Tier IV emission standards and the associated ameliorating paraphernalia.
33-37 horsepower tractors weigh 2,700 pounds to 3,700 pounds bare tractor weight.
BUY ENOUGH TRACTOR.​
Here are two Kubota model lines to consider:
KUBOTA STANDARD "L": https://www.kubotausa.com/docs/default-source/brochure-sheets/l2501.pdf?sfvrsn=34e9b1d_8
KUBOTA GRAND L3560: https://www.kubotausa.com/docs/default-source/brochure-sheets/l60.pdf?sfvrsn=bad1e991_6
/ Reality check for this newbie. What do I really need? 15 acres, but no livestock. #20
Lots of good advice here already - most of which I'd agree with though personally I'd say the first thing to consider is how much time you want to spend doing the tasks you want/need to do, and if there are any hard limits as both will drive the sizing. For example: are there any spaces that would limit the overall machine width (or height)? Are there any loads you'll need to lift that can't be made smaller? Are there any minimum heights that you'll need to reach with a loader?
The thing that I've noticed is compact tractors tend fall into one of two buckets; the first is the "deluxe" models which tend to be larger framed & heavier for their horsepower (and have features which seem like "luxuries" but can actually greatly increase productivity). The second is "economy" compacts which tend to be lighter and have higher horsepower (essentially a PTO on wheels). Both have their uses, and it's worth considering which best fits your needs.
Subcompacts can be very useful, but they are small -- and that can be both an asset and problem. While they can do many of the same tasks as a larger tractor it's going to take longer and may require more work. For example a fallen limb may need to be cut into smaller pieces for a sub-compact, where a larger tractor might have been able to pick up that same limb without any cutting involved. However, that larger tractor may require it's own storage solution as it may not fit through a standard garage door. Granted the other thing to consider is that the capability for dollar value also tends to favor larger tractors (i.e. generally more bang for the buck the larger the tractor), but (like most mechanical things) letting them sit unused can result in problems (usually at the worst possible time).
As for the thought of not getting a tractor it's worth a consideration (it may even be worth looking at other options like Bobcat's Toolcats, compact telehandlers, or skidsteers - or renting equipment if/when needed).
However, I'd say that with the three acres (2/3rds of which is fenced in pasture) I own, and having used riding mowers, and zero-turns to maintain the only the lawn portion of my property buying a compact tractor made the most sense (both financially and capability-wise) for my situation ...which includes mowing my entire property, handling the pruning, removal, and storm clean up with several large trees on my property. The smallest oak on my property was >21" in diameter when I removed it last year and it had to go as it was dying from being over shadowed by two larger oaks (the top 1/3 of that "small" tree was dead & rotting).
So I'd say it's really worth looking at your situation and what you want (and may need) to do long term -- and sometimes backing up to look at other options can be of help to ensure that you're not getting fixated on a solution in search of a problem. ...and perusing this site to see how others have used their equipment can definitely help identify things you may eventually want/need to do.
2018 MACK CXU (PINNACLE) (A60736)
2018 MACK CXU...
2017 Ford F-150 Pickup Truck, VIN # 1FTEW1C85HFB72710 (A61165)
2017 Ford F-150...
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
2025 Pabreak Hydraulic Brush Cutter Skid Steer Attachment (A61567)
2025 Pabreak...
2021 CATERPILLAR D3 CRAWLER DOZER (A62129)
2021 CATERPILLAR...
2011 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2011 DRAGON 150...
