Your elevation.
/ Your elevation. #42
24' We a little over a mile from the Everglades in se Naples 34117 . From here we about can see Picayune Strand State Forest.
/ Your elevation. #43
404 feet.
Maybe your "location" should say "downstate". :D
Downstate ? I'm close to Albany.
Fact: Albany waterfront experiences tides.
Living further "upstate" near the Hudson River where it rolls out of the Adirondack Mountains and there's waterfalls and stuff, it's very weird to be near Albany and see the same Hudson River flowing north back towards those mountains! :eek:
p.s. I live at about 550' elev. above sea level, in the Lake Champlain drainage basin (the temporary forgotten Great Lake :() .
/ Your elevation. #45
Oh Wow, I never thought about you being that low. :)
The boot heel of Missouri near the Mississippi is about 28'.
Where I grew up in Montana it about 3,200 at the house.
However here in SC its just less than 600'.
/ Your elevation. #46
930’ here in the foothills of the Cascade mtn range.
/ Your elevation. #47
Our driveway is at 1380' in the Berkshire Hills.
/ Your elevation. #51
Yep, the Hudson only drops about 5 feet from the federal dam to the battery.
/ Your elevation. #52
If I lived in the FL Keys the highest I could be is 8 feet above sea level.
Since I live in SoCal I am at 2000 feet and if I am on the upper Patio, I would be at 2010 feet. Get a little snow, melts soon after it hit the ground but... I Have Seen Snow In SoCal Wine Country.
/ Your elevation. #53
Anyone that lives along the coastal shores is not going to be much higher than sea level...I have property on the west coast of FL that is only about 8'...most topos of many coastal regions will show a series of ascending ridges or terraces that parallel the modern day shore
/ Your elevation. #54
I looked at sites along the coast of the Keys before I found out two things..., one that the highest point on the Keys is 8 feet above sea level AND the HUMIDITY... did I say humidity... you can cut the air with a knife even in the evening. I was amazed by how hot and sticky it was at night. I spent two, two week trips to the Keys before I gave up on living there. Moved to SoCal.
/ Your elevation. #55
I was minus 6 feet in New Orleans after Katrina. That is how deep the water was in my den. I have since moved to much higher ground.
/ Your elevation. #57
About 910 feet here and our water flows to the Mississippi.
/ Your elevation. #58
I just drove from Lincolnton to New Bern this afternoon. My Garmin displays the elevation which isn’t terribly accurate, but it’s better than a stick in the eye. I thought to look at it a little east of Kinston. The display stayed between 52 and about 31 every time I glanced at it. Kinston is probably 60 miles from the coast.
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
2025 80in Hydraulic Dual Cylinder Root Grapple Skid Steer Attachment (A61567)
2025 80in...
2001 Ford F-550 Truck, VIN # 1FDAF56F61ED50387 (A61165)
2001 Ford F-550...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
2008 KALYN SIEBERT TRI PLEX FRAC PUMP (A60736)
2008 KALYN SIEBERT...
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
