AC 5020 / Hino E23 / MF 210 under contract.
/ AC 5020 / Hino E23 / MF 210 under contract. #1
herm0016
Carter lake, Colorado
Branson 4720h
My first real tractor. :cool2: Allis Chalmers 5020 AKA Hinomoto e23 or Massy Furguson 210 or Simplicity 9523.
mfwd with new rear tires, balasted, original loader, everything works well and well maintained. new alternator, nothing but a few small drips. should be delivered next week after the tires are done. I cant wait!
I will get some pictures and such when it gets here. anything i should do right away to it?
/ AC 5020 / Hino E23 / MF 210 under contract. #2
Pictures! Check the front axle for oil level and wear. I understand the parts are hard to come by.
/ AC 5020 / Hino E23 / MF 210 under contract. #3
Congrats! Also keep your cooling circuit well maintained and clean. We get the Hinomoto E23 here. It's known to give some head gasket issues.
She has 497 documented hours. It's been worked but everything functions pretty well . The right front leakes oil at the knuckle. Other than that there are no other leaks that are worth talking about. It has power steering from a kit that someone built for them 20 years ago. It workes well. New last Friday loaded rear tires and nearly new fronts. I have the original manuals for the loader and the tractor plus a reprinted service manual, 2 sets of filters and a quickatach for the 3 point. I would like to get a 4 ft mower and box blade for it. Moved about 18 yards of dirt and compost this weekend and got about 100 plants into our garden.
I put marvel mystery oil and power service in the silver can in the fuel, should I be using different additives?
It starts right up with just a few seconds on the glow plugs. Clutch was replaced at 250 hrs. No problems shifting in any gear. PTO engages smoothly. 20190531_162414.jpg
It had the thermostat replaced somewhat recently and seems to stay at operating temp well. Cooling system seems to be working great.
/ AC 5020 / Hino E23 / MF 210 under contract. #6
I just bought a 5020 as well. Does anyone know what kind of oil to put in the front diff? I ordered a manual, but won't see it for a week or so.
the manual says to use the same stuff as the transmission. I am using the tractor supply tractor hydraulic transmission oil. check the lash on the spindles on the ends of the front axle, i had to tighten mine up a bit, as they were pretty loose and all the oil would run out. I got the slop out and when just a touch more. the manual says something like 5 ft lbs on the top nut.
i had thought about putting a heavy gear oil in there, but was cautioned incase there are some needle bearings or smaller roller bearings where it would not penetrate well.
Good luck with it, would love to see some pictures. I have put around 20 hrs on mine since i got it and its been great. does yours have the loader? i need to replace my muffler as well.
/ AC 5020 / Hino E23 / MF 210 under contract. #8
Thanks for the reply. Mine does not have a loader. This one does not run, picked it up for$500. It seems to be in really good shape. The crank turns, so I hope the engine is ok. Bet it needs a head gasket. I'll post some pics when I get it pulled out of the barn it's been sitting in.
ha... good luck with parts. there are a few with similar tractors on the allis chalmers forums and on mytractor forum, and someone who documented rebuilding the front axle. Let me know if you want to sell it for parts if it turns out a dud. I do hope you get it going though.
worth a shot for 500 bucks i think. one thing, could you measure the side links on the 3 point? i think mine are too long. I can get you pictures or whatever you need as well. Mine has an automotive alternator on it and after market power steering, other than that, its stock.
/ AC 5020 / Hino E23 / MF 210 under contract. #10
I will. It may be a couple days before I get back out to it.
/ AC 5020 / Hino E23 / MF 210 under contract. #11
well, I finally got it drug out of the barn it had been sitting in, on a trailer and into my barn. It was not easy. This thing does not roll free even in neutral. Here are some pics. Which links do you want me to measure?50201.jpg50202.jpg50203.jpg50204.jpg
it looks all original. was it in 4x4? i can push mine when its in 2wd and in neutral fairly easy on gravel.
the link that picks up the 3 point arms, yours do look the same though. good luck. ASAP has some parts availible, i just picked up a muffler, they also have some engine parts.
/ AC 5020 / Hino E23 / MF 210 under contract. #13
the fixed link on left side is 21 1/2" center to center.
/ AC 5020 / Hino E23 / MF 210 under contract. #15
Well, I got all the fluids and filters changed and drained and refilled the fuel tank, put a battery in and it fired right up. I drove it around some and everything seems to be working as it should, but how can I tell if the FWD is working?
chain it to a tree stump and see if they turn? haha. I have done this a few times trying to pull some very large logs and stump sections.
you can engage it and make as tight a turn as possible on dirt, and see if the fronts are digging in.
does yours have 3 speeds and 4 gears? i know they came with a few transmission options. does it work like it has a syncro? mine can be a bear to shift sometimes. i almost always leave it in the middle speed.
great that it runs! very nice. i just replaced the muffler on mine a few weeks ago, all states ag parts has them for about 90 bucks. I need to do all the fluids soon. I have put about 25 hours on it, and i don't know how old they were to begin with.
/ AC 5020 / Hino E23 / MF 210 under contract. #17
Yes, it has 12 fwd, 3 rev gears. not syncro.
/ AC 5020 / Hino E23 / MF 210 under contract. #18
With a bit of practice you can upshifting on the move and not grind the gears, been doing it for 35 years with no ill effects.
yes, i do need more practice. all the manuals i have driven in my life have been syncro. 70 series cruisers, rav 4, hilux, etc.
changed every fluid in mine over last weekend, and replaced all the grease zerks. the old ones were mostly broken. lots of going back and forth to the manual to find them, using a screw extractor to get the broken ones out, run a tap in the hole, and install new. The oil in the injector pump was quite black, and that surprised me. the magnet in the engine was perfectly clean and i know the oil was 100 hrs old. so that's great. The hydraulic/transmission had a good bit of metal in it. I am sure i have contributed a bit with my gear changes, but i'm getting much better. I was thinking of getting some big magnets and putting them on the trans pan? but no way to clean them really, just take them off when i drain and hope it drains out with the rest. nut on the right side front axle is stuck, i wanted to adjust the lash in the large bearing on the axle for the steering, but could not get it to come loose, tried a cheater pipe, heat, impact wrench many times with some pb blaster and did not get it to budge. maybe next time. new filters all around as well. getting the injector pump bled was a bit of a pain, had to go back and forth about 10 times.
I would like to clean/inspect the over pressure bypass for the hydraulics, any advice there? the old girl plowed 16 inches of snow in 4x4 no trouble with my back blade for my neighbor and I about 2 weeks ago. very happy to have it for that storm!
i found some chicken scratch in the manual where the PO had written the hrs and fluids changed. so that's helpful. 100 hrs on the oil and 200 ago on the hydraulics. i see that the front axle was opened up at some point, and the clutch was replaced a about 200 hrs ago as well.
also upgraded to a harbor freight led flood light on the back, and got the tail and head lights working. used some silver polish on the lenses on mine. looks like yours has sealed beams?? seems odd they would have changed the headlights. I had to order bulbs as they are a base i have not seen before.
Electronic Towable Sign Board (A61166)
Electronic Towable...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
2019 John Deere 344L Articulated Wheel Loader (A60352)
2019 John Deere...
Dishwasher Outlet Table (A60352)
Dishwasher Outlet...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A61567)
Challenger MT275B...
2011 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR3BJ325816 (A61165)
2011 International...
