maizeandblue
Member
My steering ball joint broke last week on my 3525. Did not find the castle nut/shaft. It appears to have broke where the threads start/stop. On the backside of hole where the ball joint is attached to the tractor, it looks as if there was a fender washer (see attached pics). Replacement part only came with the ball joint, castle nut, and rubber boot. None of the diagrams available show this in great detail and i have the shop manual. It only shows the power steering cylinder with the ball joints (one on each end), but nothing at the castle nut location. This is on the tractors right side as you are sitting on the tractor. If you have a 3525 i would greatly appreciate a pic showing the front and back of this location (see my pics).
I believe all i need is a fender washer. As you can see in the pics on the backside there is a large ring (evidence something like a fender
washer was there but i want to be certain i put it back correctly. thanks
