Battery Condition
/ Battery Condition #1
Chaos USMC
South Central Pennsylvania
TYM T503, 1962 Case 530 Case-a-matic
Regarding my TYM T-503, most recently, during the first start of the day, it seems to have a battery that "might" be on it's way out. Very sluggish start the first time, but kicks right off on subsequent starts. Granted, temperatures are getting cooler (no lower than 40' overnight) but nothing much cooler.
The closed cell battery has a small visual indicator on top and it indicates green. I measured the battery before starting and it was over 12VDC. I tested the battery with a load tester and it was not perfect, but, not bad. Once the tractor is running I get a little over 13 V at the battery terminals.
The battery is probably 7-8 years old. Because of the very sluggish starting, I am wondering if it is ready to crap out at any time, or, something else is possibly going on. Any battery experts out there that might comment?
Thank you.
/ Battery Condition #2
7-8 years old: Could be on way out.
Like you say it is getting colder out. Do you use a block heater? What is engine oil weight?
A battery below 12.4V is probably partially discharged.
13V when charging may not be enough at lower temperatures to fully charge battery, depending on running time. I think you want alternator putting out something in the 13.8-14.2V range.
/ Battery Condition #3
7-8 years, the battery has done it's job. Get a new one, higher ah rating in the same physical size if possible.
/ Battery Condition #4
Before you spring for a new battery, which is quite likely heading out.
You can put a trickle charger on the battery over night then check the first start of the day.
If it's fine thats just another indication that it is the battery, it could be under charging but more likely a weak battery.
/ Battery Condition #5
A fully charged 12v flooded cell battery should read 12.6 volts or higher. At 12v, the battery is only 50% charged.
Since you have a low charge voltage and a questionable load test, I'd just replace the battery.
And do yourself a favor, when you bring that new battery home, put it on a charger and fully charge it. Then put it in your tractor.
I'm betting with a new fully charged battery, the charge voltage from the tractor will be higher as well.
/ Battery Condition #6
It's probably the battery, but:
Wouldn't a test be: Charge battery (with a charger above 13.8V) for sufficient time. After charger removed, then, (say) the next day, check battery to see if voltage has stayed near the 12.6V range?
If it stays near 12.6V, it might be a case that alternator wasn't fully charging battery; but if it's going back below 12.3V it's probably battery.
You probably don't have a leakage current (parasitic load) that's drawing battery down, but I'll throw this out here: Another test is to disconnect one terminal of battery from tractor. Then measure if there's any leakage current running through meter (ammeter setting) when you re-complete the circuit by using the meter probes. Do this when all tractor battery loads are turned off. There should be no leakage current that drain battery when off.
...better yet: Do the disconnect and test for leak current at the ground cable where it connects to frame. Then you can clean this connection and make sure no paint or corrosion is inhibiting a good ground connection. Resistance by a weak connection at this location is often a common cause of "weak starting".
/ Battery Condition
Thank you to all, great discussion points.
Went back to the barn and took additional readings at the battery terminals: Static Battery - 12.67V. Turned key on and let glow plugs cycle - 12.18V. After tractor start - 13.5V. BTW, OAT was 47' and tractor is serviced with Rotella T4 15w-40.
I apparently did not have enough cranking amps left after waiting on the glow plugs to warm, she groaned once or twice and then refused to go any further. I quickly cycled the start switch and she "just" barely had enough to start. Put the battery on a maintainer/charger and will check capabilities in the morning.
/ Battery Condition #8
If you went out and found it to be 12.67V, that's what it will probably be tomorrow after taking charger off (and waiting a bit). That is, I doubt battery voltage will charge any higher as this is a "good" number.
But the voltage doesn't tell how much capacity battery has.
Not sure, but glow plugs pulling voltage own to 12.18V might be indication of weak battery. I'd guess that a healthy battery would recover to a better voltage after cycling.
I'd disconnect and clean (wire brush) where the negative cable from the battery attaches to frame to ensure good metal to metal contact. If that doesn't help...new battery should.
/ Battery Condition #10
A battery like described may last a week or a couple of years yet...regardless if you have not done so I would check all the main cable connections for the battery paying special attention to where the main ground wire connects to the tractor...it may look OK but not be under the washer etc...they are prone to vibration and cause intermittent issues...
Good Luck..
/ Battery Condition #11
What happened to the old fashioned way of using a battery hydrometer to check condition? I had a NAPA battery with one bad cell a couple of years ago and charged it over night with a slow charger then checked them all with a hydrometer and found one low cell, took it in and they checked it with a new fangled electronic tester and it said it was fine. I ended up having to buy a new hydrometer from them to prove my case and the owner, another old guy, said "He's right, give him a new battery."
I realize that with a lot of the new batteries being sealed this isn't possible but I'm careful when buying them and have pretty good luck with the old way.
/ Battery Condition #12
A new battery is less than $150. How much aggravation will you have in the middle of winter when it fully dies in a snow storm. After 5 years or so your on overtime with battery's
/ Battery Condition #13
If you still have problems after checking all battery connections and the main ground connection, I'd suggest hooking the battery up to a desulfating battery charger/maintainer. As long as a cell is not shorted, such a maintainer can often recover a weak battery. (If a cell is shorted, you might be able to charge it up to ~12.6 volts, but if you disconnect and let it sit overnight it will not stay there.)
/ Battery Condition #14
Using a battery Battery Tender, Battery Minder, Noco Genius, or similar, I often get 8+ years from a battery.
That said: In a Northern climate, you should expect trouble any day, if you keep a battery beyond 5 years.
/ Battery Condition #15
I think it’s time for a new starter. Or rebuild the old one.
/ Battery Condition #16
My understanding is a cell's specific gravity, as measured by the hydrometer, directly correlates to that cells voltage. Thus if the specific gravity is low, cell's voltage is low, and the battery's total voltage will also be low (as measured by voltmeter from post to post).
Ideally each cell should hold 2.1 volts (x 6 cells) = 12.6 voltage. So if you only get 12.1V or something less than 12.6, yes a hydrometer can tell you which cell is bad, or if all cells aren't fully charged. But I guess my question is: So what?
/ Battery Condition #17
I went the simple route. Last year the OEM battery on my 2009 Kubota was nine years old. I replaced it with an Odyssey. The OEM battery has been moved into a standby category.
I DO NOT need the hassles of a weak battery.
/ Battery Condition #18
With a battery that is 7 or 8 years old, I wouldn't waste time checking anything. Just buy a new battery. You certainly got the good from that one. My Kubota B26 started turning over weakly but still starting at about 7 years of age. Then one day when it started getting colder and required more preheat, it just wouldn't start. A new battery got it going again.
Now if you had this same problem with a fairly new battery, then testing would be in order. Battery voltage is not a good indication of a good voltage, load testing the amperage tells you the battery's ability to rebound from a load which gives you the condition of the battery's plates.
/ Battery Condition #19
Hey, now there's a good suggestion. New starters do come with new tractors. :D
/ Battery Condition #20
How do you check a sealed top battery with a hydrometer? Load test after a full charge cycle is the only way to verify the condition of a battery.
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
2016 Bobcat E85 Midi Excavator (A56857)
2016 Bobcat E85...
John Deere 2155 (A62177)
John Deere 2155...
208735 (A60430)
208735 (A60430)
2024 Schulte 5026 Batwing Rotary Cutter (A63688)
2024 Schulte 5026...
2025 Auger Bits Skid Steer Attachment (A61567)
2025 Auger Bits...
