Traction Incredible - No damage resulting from putting gas into my Kioti Diesel Engine
/ Incredible - No damage resulting from putting gas into my Kioti Diesel Engine #21
I'm assuming that starting the older diesel engines on gas was to pre-heat them? No glow plugs or other cylinder head heating on those types?
The mechanical injection systems are probably more tolerant of gas or other non-diesel fuel, but I think that will depend heavily on the type of pump. I know the Bosch pumps used on the older mechanically injected VW TDIs (not in any tractor that I know of, but wouldn't be surprised to see other flavors of Bosch pumps or their patents used in tractors) tend to have very tight tolerance, and even short operation with watery biodiesel or gas could cause pump failure from lack of lubrication.
Aside from pump and injector tolerances for modern emissions, a diesel engine will run on just about anything that will burn. Rudolph Diesel originally built his engines to use soybean and peanut oil.
/ Incredible - No damage resulting from putting gas into my Kioti Diesel Engine #22
MY OLD JD "A" WAS MADE TO START ON GAS AND THEN SWITCH TO KEROSENE. I THINK TO WARTM IT UP ON GAS FIRST. ALL THROUGH A CARB. I'VE RUN IN ON GAS ONLY FOR YEARS. OCCASIONALLY, A FRIEND THAT WORKED AT ELECTRIC CO. WOULD BRING ME A HALF A BARREL OF MIXED FUEL AND GAS FROM A TRUCK SOMEONE HAD MESSED UP ON. I COULD RUN THE OLD TRACTOR ALL WNTER ON THAT MIX. DIDN'T START VERY WELL, BUT IT WOULD RUN.
/ Incredible - No damage resulting from putting gas into my Kioti Diesel Engine #23
Don't forget, Red Sharpie for Gas, Yellow Sharpie for Diesel, Blue Sharpie for Kerosene
I am one of those stupid people that puts gas only in red jugs. I have two yellow ones for diesel in case my little diesel fuel station runs out before I get it filled.
I use a Sharpie to mark my 50:1 mix containers...one in the pole barn...one in the garage.
Good to hear there was no damage to your tractor but a change in how you store fuel would be prudent.
/ Incredible - No damage resulting from putting gas into my Kioti Diesel Engine #24
rademamj...Welcome to the forum. I feel that some of the replies were too harsh, anyone could make the same mistake while tired or distracted.
The Mahindra is the first diesel machine on the place, I immediately ordered a yellow (diesel) can off Amazon to prevent such mistakes.
As mentioned, the lack of lubricating properties of gas is the issue at hand, evidently the residual film of diesel and your prompt response saved you from damage.
I would recommend that you get a yellow can strictly dedicated for diesel.
/ Incredible - No damage resulting from putting gas into my Kioti Diesel Engine #25
Years ago, Mercedes came out recommending up to 10% gasoline in diesel as a fix to winter diesel problems. Then they rescinded that when they found out that such a mix can cause a very explosive atmosphere in the fuel tank. Normally, diesel tank atmosphere is too lean for an explosion to happen, and gasoline tank vapor spaces are too rich.
Good to hear that nothing bad happened, which enhances my feeling about any needed "lubricity" for today's diesel fuel. You lost it with the gasoline. The fuel injectors are designed for low/no lubricity needed. Probably the lobes or whatever in the pumps don't actually touch.
I use red and blue "cans" for diesel but clearly mark them as DIESEL.
Ralph
/ Incredible - No damage resulting from putting gas into my Kioti Diesel Engine #26
Ralph
That one confuses me. VW uses the exact same tank and in-tank pump for their gassers and their diesels. Diesel doesn't emit much vapor at normal atmospheric pressure and temp, while gasoline emits vapor at around 77 degrees Fahrenheit. And it's the vapor that "rapidly combusts", or explodes. (Neither liquid gasoline or liquid diesel will ignite.) I can't see how putting both gasoline and diesel in the same tank would cause a problem. (Now, you are not supposed to fill a gasoline tank to the top because there needs to be room for vapor expansion, while this isn't necessary for diesel...)
/ Incredible - No damage resulting from putting gas into my Kioti Diesel Engine #27
. The problem is that diesel fuel has low volatility and a high flash point, so it is too lean for the tank fumes to ignite.
Gas has a very low flash point but very high volatility, so the fumes in the tank are too rich to ignite.
Combine a little highly volatile gas with a volume of low volatility diesel, and you have the conditions for a tank explosion, ie the a/f ratio of the tank vapors are in the region that it could explode.
/ Incredible - No damage resulting from putting gas into my Kioti Diesel Engine #28
Also, some quality fuel containers use a different spout/cap gasket material for gasoline vs diesel. Eg. Scepter military red jerrycan containers need "Viton" material gaskets. Their yellow-diesel/blue-water can gaskets can't survive gasoline and will crack like crazy. I learned this the hard way.
/ Incredible - No damage resulting from putting gas into my Kioti Diesel Engine #29
my wife accidentally topped off the dodge diesel with unleaded gas about 4 years ago. truck drove out of the gas station and promptly died. Truck was towed to Dodge where they determined what happened. $600 later after tank was dropped and drained and cleaned, truck was refulled and has run fine ever since. The dodge mechanic wasnt worried. said hes seen it before
Modern diesels are more finicky, but I suspect with just a bit of luck, OP's tractor will be fine.
Lubrication is one aspect that's been cited already.... along those lines, Ethanol content in the gasoline is a factor..... not recommended at all usually in modern diesels, but pure gasoline would be the least detrimental. It wasn't just my better sense of smell back when - high sulphur diesel fuel was pretty easy to distinguish from gasoline. (We need a tin-foil hat smiley..... maybe this low-sulphur diesel is just a plot to get more gasoline into diesels !). ;)
A customer's RAM came into work, because a worker had filled the DEF tank with diesel. Not saying trying DEF in a diesel tank is good :rolleyes:, but I can say that filling a DEF tank with diesel gets expensive.
Mistakes are wasted if not learned from (I've managed to learn from most of mine :D), Fluid foul ups happen, but aside from no time to wait (under fire), that's one reason a lot of military equipment is designed to run on pretty much anything....
Rgds, D.
/ Incredible - No damage resulting from putting gas into my Kioti Diesel Engine #30
The older I get, the simpler I try to make things. It ticks me off when I make stupid mistakes, knowing full when that the mistake shouldn,t of happened. Hopefully adding gas to your diesel engine didn,t hurt it.
/ Incredible - No damage resulting from putting gas into my Kioti Diesel Engine #31
get one of these...not only will it make your life easier, you cant possible use wrong fuel. fule 2.jpg fuel 1.jpg 38118_700x700.jpg
I know exactly what you mean dumb mistakes. My mistake came at the very end of the day, working seven hours with the tractor doing stump grinding and wood chipping. Temperature was 98F in Texas that day, and certainly contributed to my lack of focus. I have Gas clearly marked on my yellow cans and Diesel clearly marked on my red cans, and i still made this dumb mistake. The injectors were pinging loudly, so there was mechanical noise from those injectors. The good news is, after 11 hours additional use on the tractor, I have no problems. But still waiting for the Tier-4 DPF emissions to enter a burn cycle. The gas in the fuel, triggered an immediate DPF burn, which was stronger sulphur smell than normal.
The outcome of this is accidental use of gas in a diesel engine, for a short time, probably will not result in damage. Full drainage of the tank and replacing the fuel filter helps to full recovery.
/ Incredible - No damage resulting from putting gas into my Kioti Diesel Engine #33
Ralph
Good post! I hadnt thought of that effect.
Essentially, yes.
A physical conception is helpful to appreciate the effect:
. . . In a solution the solutes sort of get in the way of solvent properties. Examples are freeze point changes of water with addition of anti freeze, salt, sugar, etc. The phase change to gaseous state is also affected, but not as obvious.
In a diesel/gasoline tank mix the inhibition of gasoline evaporation is more quickly offset by re condensation back into to liquid from the overlying trapped atmosphere. As gaseous gas becomes more concentrated an equilibrium arises where evaporation = condensation. This equilibrium point can more readily be explosive in a mixed tank.​
/ Incredible - No damage resulting from putting gas into my Kioti Diesel Engine #34
Nobody likes making mistakes, but I've also come to appreciate "A Bad Accident is one that money can't fix".
With just a bit more luck holding, you may well have dodged a bullet :thumbsup:.
Who Knows ? Not suggesting that you repeat the tactic, but maybe you just pulled off an excellent cleaning of the DPF !
Rgds, D.
/ Incredible - No damage resulting from putting gas into my Kioti Diesel Engine #35
It may be reassuring to remember that there are multifuel engines out there designed to run on both gas and diesel.
Reo multi-fuel army trucks were one example. If I remember correctly, Reo called that truck the Eager Beaver. I never owned one, so I don't know what was required to switch from one fuel to the other.
I do have a Rolls-Royce K60 diesel that is called multi-fuel. I've never run it on gasoline, but the manual says it makes the transition automatically, depending on the density of the fuel. Again, I'm not sure what is involved, but apparently it changes injection timing, possibly amount of fuel injected, maybe other things, but it does run both fuels through the same engine.
On the subject of the old Mercedes diesels, I had a few vehicles (180d, 319d) powered by the om636 engine. One thing I remember about them is that the injection pump didn't depend entirely on diesel for lubrication. One extra task on that engine was checking the level of lube oil in the sump of the injection pump.
/ Incredible - No damage resulting from putting gas into my Kioti Diesel Engine #36
...On the subject of the old Mercedes diesels, I had a few vehicles (180d, 319d) powered by the om636 engine. One thing I remember about them is that the injection pump didn't depend entirely on diesel for lubrication. One extra task on that engine was checking the level of lube oil in the sump of the injection pump.
Mechanical Mercedes Diesel injection pumps are removable units that included the camshaft that operated the plungers. The older style (as cited) had its own oil reservoir to lubricate the camshaft, tappets, and rack/control sleeves and that oil required periodic change. Newer Mercedes Diesel injection pumps were lubricated by the regular engine oil so it got changed with every oil change.
Our agricultural Diesels are different. The camshaft is inside the block and driven by the gears on the front of the engine. So the bottom end of the injection pump (camshaft, tappets, rack, etc.) is easily lubricated by engine crankcase oil. Still, the plungers and close-fitting cylinders (plus injectors and delivery valves) are lubricated only by fuel. So I have to wonder how long they would survive on 100% gasoline.
/ Incredible - No damage resulting from putting gas into my Kioti Diesel Engine #37
About 15 minutes..{max}
/ Incredible - No damage resulting from putting gas into my Kioti Diesel Engine #38
I'm surprised you would give it that much time,
I would have guessed less then a minute with 100% gas, a blend which is the most likely to happen could give a chance at longer.
/ Incredible - No damage resulting from putting gas into my Kioti Diesel Engine #39
I致e always put whatever fuel I want in whatever can I have. Apparently some people can稚 see and smell the difference in gas and diesel.
its thinking like this that results in things like, different countries driving in opposite sides of the road, different countries using metric and AF bolts, and having beta and VHS video cassettes at one stage.
oh and by the way i have done this b4, one of the petrol stations in town insists on having a black hose on their premium unleaded pumps, the same colour everyone else uses here for diesel. fortinately i realised before i attempted to start the engine, but was a hassle aranging a frind to tow me to his workshop to lift the car on the hoist and drain the offending fuel from the tank. plus having to pay for 80 litres of fuel i didn’t want.
/ Incredible - No damage resulting from putting gas into my Kioti Diesel Engine #40
If I were you I would pull this post down just in case you ever have a problem with your motor. If Kioti sees it you will lose your warranty on it for running it with gas in it.
Skid Steer Trencher Attachment (A61567)
Skid Steer...
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
John Deere 544H Articulated Wheel Loader (A61567)
John Deere 544H...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
