Buying Advice Buying 2006 Kubota L3400 with under 300 hours
/ Buying 2006 Kubota L3400 with under 300 hours #1
boostmg
Pennsylvania
Branson 3620 TLB Hydro
Hey guys quick question here .... someone is selling an 06 (garage kept) Kubota L3400 Hydro about 3 hours from me.
It has the backhoe and ag tires.
It's essentially the perfect tractor IMO however it's 13 years old. He has 275hrs on it and is asking 21k.
Is there any potential downside to buying it given it's age?
Some of my concerns would be the coolant/hyrdo hoses, tires dry rotting, etc ... anything else that could deteriorate or dry rot over 13 years.
Otherwise I personally wouldn't have any issues with it, also I like that it's pre-emissions.
Help is appreciated thank you in advance.
/ Buying 2006 Kubota L3400 with under 300 hours #2
If it has a backhoe or a lot of implements than maybe but that’s more than it costs new and about equal to a new one today. Personally I’d buy a used Grand series. They’re much better tractors.
it has a backhoe.
The problem i'm running into shopping used its finding tractors with backhoes with lower hours and $20k or under is hard. Also with specific HP range .. i would like 30-35hp
/ Buying 2006 Kubota L3400 with under 300 hours #4
Whats one cost new? That seems a little high based on its age, not the hours. If it was store inside, it might be in good shape.
/ Buying 2006 Kubota L3400 with under 300 hours #5
Check the unit out but tires and hoses are probably still fine. Tires should be good for thirty or forty years and hydraulic hoses may go longer than that.
Anything in the new range that has 35 hp with a backhoe is like $35k+ .... anything around 30hp w/ hoe is around $30k.
I really like pre emissions
/ Buying 2006 Kubota L3400 with under 300 hours #7
That's probably not out of line on then the price then.
/ Buying 2006 Kubota L3400 with under 300 hours #8
Sounds like you did your research on new for that size. Under 300 hours is a barn find in my opinion if it's not beat up. I had an L3400 and it was a workhorse. They are great tractors.
/ Buying 2006 Kubota L3400 with under 300 hours #9
If you buy it ask and make sure your getting the 3 point arm etc set up with it . Sometimes buyers forget till they take b-hoe off to put attachments on .
/ Buying 2006 Kubota L3400 with under 300 hours #10
Unless you are a devout tree hugger, there is no reason to like emissions diesels.
/ Buying 2006 Kubota L3400 with under 300 hours #11
Depends on the quality and how much time it was in the sun.
I just replaced a dry rotted hydraulic hose on my backhoe that was only 3 years old. The backhoe stays outsife but this particular hose is shielded.
My hose supplier was using some "Made in Italy" hose for a while. I hope they don't all follow along. They have switched to a different brand but it's still foreign made.
My last hose I had made I went to the Carquest and paid for made in the USA Gates hose and fittings.
/ Buying 2006 Kubota L3400 with under 300 hours #12
The tires on my 2015 Kubota are already cracking. I am in the process of putting up a building, but until then I have no choice but to leave it outside.
I may offer the guy 18.5. He may not take it.
Do u think I壇 be making a mistake paying $20k for a 2006?
I just got off the phone with him and they used it during constructing of a cabin and since then it痴 mainly been sitting. He says it痴 too hilly where he is to be cutting with it. So it was mainly used for trenching digging dirt moving.
He also has filters for the next service. It has 270 hrs on it.
He said at one point he got a flat in the front and the dealer patched it up. It has the original battery.
He said tires and hoses r good. Tires aren稚 loaded.
He has 3pt hitch with it and ROPS.
Also i live 2.5hrs away from it so he says he knows a guy who can transport. He told me he?d take $20k delivered for it.
/ Buying 2006 Kubota L3400 with under 300 hours #14
I think it’s about 20-22 new without a backhoe. I think that’s about $8500 more. Does anyone that’s actually bought one recently know? Having a backhoe it’s probably not a bad price. Being garage kept I wouldn’t worry about it being a 2006 either.
/ Buying 2006 Kubota L3400 with under 300 hours #15
IMHO sometimes it is worse for a machine to sit for a long periods of time verses use it a little more with higher hours.
I agree. It sounds like he would start it up and stuff. But not for long
I知 very on the fence about all of it.
/ Buying 2006 Kubota L3400 with under 300 hours #17
Have you thought of driving the 3 hours and having a look at it? Meeting the seller and a hands on inspection would eliminate your apprehensions.
Yes i may do that this weekend actually
/ Buying 2006 Kubota L3400 with under 300 hours #19
Here is info for comparison:
This past June, I bought a 2006 Kubota L48 with 250 hours (on CL) from the original owner.
It was an 8 hour drive away, but I had a long ago college roommate who lived very close to the seller, go to look at it.
His report was that "it looked good", but had some areas of surface rust.
It had lived it's entire 13 years of life to date outside.
I did not like that!
I thought I trusted my friend, but I did consider that the story might not play out the way I would like it to.
The L48 is a medium size industrial TLB, and although the model is no longer made, the new replacement model is pushing 60K.
I would have never considered a new one at 60K. This was just an early toy, for my 79th birthday,.... next month.
The machine has all the bells and whistles.
Hoe has a nice hydraulic thumb
There are 3 rear remotes.
There is also one front remote, and that has a diverter.
The diverter allows locking on to any loader attachment without leaving the seat....very sweet item.
A 24" quick attach backhoe bucket.
A 13 year old Kubota 48HP TLB with 250 hours.
I paid 32K.
Perhaps that number will help for comparison purposes.
Hydraulic hoses are all very good.
Diesel fill rubber grommet was bad....I have replaced it.
Tires show some very minor weather checking.
The seat cushion was torn, and I replaced it with an aftermarket seat.
Both fenders had minor underside surface rust, and I removed them, sandblasted, primed, and repainted.
I have refreshed the instrument console with 3M 303.....looks like new now.
I have repainted two small areas of the forward frame, and the grill guard, to get the gloss back.
I like refurbishment projects like this, and when I am done, the L48 will look very close to new.
I will buff the tractor, and loader parts, but the hoe is well on it's way to Mary Kay pink.
I do not like Mary Kay pink !!!
I think I will give just the hoe, a repaint next summer.
Although the machine did live outside, it was in Maine, and was shaded by tall spruce trees.
It is a nice machine!
I am satisfied with my purchase......and...
Maybe 28K less than a new one?
/ Buying 2006 Kubota L3400 with under 300 hours #20
I have a L3700SU HST with the loader and backhoe,basically the same as the 3400 about 280 hours and about 7-8 years old. I bought it new and it was about 26k... I wouldn't sell it for 21k today. At 300 hours it has decades of life left in it.
