Good morning!!!!
   / Good morning!!!! #100,431
wngsprd
Thomas, hope the Weathervane was good.
Had to loosen belt little. ;)
Getting fire wood in just seems like last week your stay low of 90's.
   / Good morning!!!! #100,432
   / Good morning!!!! #100,433
I did Rick. A line by line comparison and the FM-BH8 was identical to the LB2100 except .9 inches increased reach and +139 lbs bucket digging force, but the biggest factor for me was more than $3k savings even after adding 2nd bucket, ripper, extended warranty. That made it less than 2/3 the LS price my dealer quoted and that included shipping for the BH8 but not state taxes for LS.
The PTO hydraulics were a non issue as no choice. Looking at it in real life, I don’t see why it couldn’t be converted to tractor powered. That would likely be my fix should the PTO setup fail. In fact someone with more knowledge could probably Tee In and make it either/or.
Having had 3 FM flails over the years, I was fairly confident this would be a good build. Compared to my Kioti kb2375, not disappointed. Would rate build and finish as equal or better.
I do have thoughts regarding a future frame mount, but not near future. My reasoning there would be easier mounting/dismounting. I’ve only mounted this one the 1 time. Compared to my frame mounted Kioti, not that more difficult. I almost always was challenged to get proper alignment with the Kioti subframe. I’m thinking my initial challenge with this bh was not getting started at proper height. Once I got that corrected it went well. Mybplan is modify my dolly to facilitate. With the subframe, unless I had a 2nd person I was repeatedly on and off the tractor. With my dolly, I envision just moving the bk into position with tractor remaining stationary.
Hope this helps. Just ask if anything else or like pics of anything.
Thanks David ..... very informative. I'd heard stories of issues with 3 point mounted backhoes causing tractor problems with rugged use. I suspect the issue was probably with the "smaller" tractors and "aggressive" operators.
I hoping that LS somehow realizes their pricing is a bit high. What I do like, with their LB-3104 is;
Sub-frame mounted.
No need to remove 3-point arms.
It runs from tractor hydraulics.
It doesn't look like they offer mechanical or hydraulic thumb though. I would prefer hydraulic.
   / Good morning!!!! #100,434
64F blue sky not a cloud.
7 hours blowing leaves :( already for next dumping.
While taking hour lunch break Boo Boo decided to knock over burn barrel. :rolleyes:
I am done for today Mrs. going to do some grilling :licking: watch little football nascar think I'll hit pillow early tonight.
Enjoy the evening all.
   / Good morning!!!! #100,435
Got some salmon fillets marinating to grill on the Primo. Wife cooking up brussel sprouts. Friend bringing Tater Tots for the air fryer.
   / Good morning!!!! #100,436
RNG,
Do you have bolt-on forks on your bucket, or a QA fork unit? If bolt-on, how do you like? I'm thinking of getting some forks to improve life here. I'm getting ready to bring a pallet of firewood up to the porch...and I use a carry all which is very difficult to slide the angle iron into the pallet, especially since pallets have sagging tops.
BTW, wish I could find a breakfast place here like Jen's.
Couldn’t imagine giving up my QA forks. I use them more than the bucket.[/QUOTE]
Me too. Bought mine yrs ago from Markhams that used to be on TBN. I had pin on bucket then so bought QA adapter to use them.
   / Good morning!!!! #100,437
Me too. Bought mine yrs ago from Markhams that used to be on TBN. I had pin on bucket then so bought QA adapter to use them.[/QUOTE]
Thanks for comments on the QA forks. I'll read your thread, too, RNG. I have a QA bucket on now, and the EA grapple goes on it easily, so will start there looking at QA forks.
   / Good morning!!!! #100,438
In my tractor log, I keep record of what I was using, forks, bucket or BH. Then it goes in a spreadsheet.
   / Good morning!!!! #100,440
I’m happy with Samsung French door fridge w freezer bottom. Ice only in freezer. Deeper than counter.
2015 Ram 5500 Versalift SST-40NE 40ft Sign Bucket Truck (A55852)
2015 Ram 5500...
WB 17" PIN ON EXCAVATOR BUCKET (A52707)
WB 17" PIN ON...
2013 Chevrolet Impala Sedan (A55853)
2013 Chevrolet...
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
2019 Ford F-250 Super Duty Crew Cab (A55852)
2019 Ford F-250...
