Snow Equipment Owning/Operating Am I making the right choice????
   / Am I making the right choice???? #1
Woody65
Gold Member
East Northport and Oneonta NY
John Deere 4300 HST 4wd
I have decided to set myself up this winter for snow removal on a 1/4 mile long steep mountain gravel driveway. Its a pretty steady incline of 220' over about 1000' of driveway. We use the place for 3 seasons and hunting season which ends in mid December. But would like to use it a few times in the winter months. Hence, the need for snow removal.
The three choices I came up with were:
1. outfit my JD 4300 with a front snow plow blade and chains. This cost was $4,400. Cons- no heat, no radio, no cab...
2. outfit my Mule pro-fxt with all the necessary do dads for a plow set up. Cost $3,000. Cons- no heat no radio, no cab, limited capabilities...
3. outfit my 2000 chevy 3/4 ton extended cab 8' box 4x4 with a 7'6" Fisher minute mount plow (free from FIL). Need to have harness and frame mount put on and tire chains. Cost $2,700. Cons- cant think of any
The chains would be the V-bar heavy duty 2 link variety.
I would place 2 snowmobiles in an enclosed trailer in the field next to the driveway at the bottom and use them to traverse the driveway when I arrive. The plow vehicle would be at the top in a barn.
Any and all comments welcome.
   / Am I making the right choice???? #2
I plowed a 1/4 mile driveway in Dutchess County with a cabless tractor with front plow and rear blade or blower for almost 30 years. If the truck is reliable enough, go that route. Put 1000 lbs in the bed. Tractor would be second choice, UTV isn’t a choice.
   / Am I making the right choice???? #3
1.You should be able to put a front plow on your tractor for way less than $4000,find an old truck plow(many here have done the same)
2.UTV are ok if you are there to keep up with the snowfall,probably not going to bust open a plugged drive.
3.Truck sounds like the least expensive and warmest solution.
The truck is a daily driver, so its in good shape. I liked the tractor option but since I don't reside there I could be plowing in nasty weather out of necessity. No control over weather when I arrive. Thanks for the advise
Don't have the welding skills to fabricate the necessary mounts to retrofit a truck snow plow to fit my tractor. I just missed out on a JD front plow on craigslist for 1,000. It was like new and sold in less that 12hrs. Snooze you loose.
I figured the UTV would be useless with the road end of the driveway. Thanks for your comments
   / Am I making the right choice???? #6
My worst case scenario was plowing snow in the rain at the tail end of a storm so the wife and I could get to work. Extremely unpleasant.
   / Am I making the right choice???? #7
I would go with the truck plow. Believe it or not, nice 3/4 ton and up trucks don't get beat up when :
The owner is operating it.
You don't drive around with the plow unnecessarily.
You're not plowing commercially, or a bunch of driveways.
   / Am I making the right choice???? #8
I do not know how much snow you get, but here in north idaho if you do not keep up with it throughout snow season.... a plow is not going to move it. I had a neighbor come and beg me to snow blow their drive last year ... they had been in Nevada for months... snowbirds. They hired a local plow guy that got his truck buried in the 4 feet of snow on a 400 ft driveway. No place to push it as they did not keep up with it. The blower did the job, but even that took time. No way a sxs would have touched it.
a pto mount snowblower wouldn稚 cost too much more than plow, and you might not need chains.
   / Am I making the right choice???? #9
Truck plow and you can use the tractor to push back the banks when needed. It's nice to be inside a warm cab. Plowing downhill is is pretty easy unless you have to back up in the slippery stuff, especially if the lip of the plow goes over a solid snow bank. Be prepared for that or leave chains on the truck. The mounting cost seems kinda high for already having the plow. You may want to look at used parts and pay someone for just the labor.
I would only be plowing, at the most, 5-10 times a year. The plow truck would stay exclusively on the property during the winter. The rest of the year I use it for hauling the occasional trailer or building supplies. Thanks for your comments
2007 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A56858)
2007 Chevrolet...
2003 Big Tex 10PI...
UNKONW  SPOOL TRAILER (A58216)
UNKONW SPOOL...
FORD TRUCK BED MAT (A52708)
FORD TRUCK BED MAT...
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
Gorman Rupp 14D52 10 Series Centrifugal S/A Towable Water Pump (A56857)
Gorman Rupp 14D52...
