What to add a 3rd function
/ What to add a 3rd function #1
Halcomadam
2018 jd 3032e
I was looking around on the tractor and noticed that there was a quick connect under the tractor which I cant seem to figure out what it would be for any thoughts would greatly help IMG_20191006_193035515.jpgIMG_20191006_193022385.jpg
/ What to add a 3rd function #2
A return to tank port. A direct return to tank line is required or at least recommended for various implement hydraulic functions.
Okay thank you
I've been looking on how to add 3rd function but all the kit are way overpriced from what I can tell I can make all my own custom hose so all I'm in need of is the valve and the electric components if someone could lead me in the right direction
/ What to add a 3rd function #5
I felt the same way. I ended up spending about the same as a pre-made kit (W.R. Long) but I had to buy everything and I added a few features / changes that weren't included in the kit.
Biggest thing to look out for is sizing your valve to the hydraulic flow of your tractor.
I have attached the write-up I did when I built mine, this is not THE way it's just A way.
Hopefully it will give you some ideas. Best of luck on your project.
  • 3rd function build - Revised.pdf
