The ground wire in the picture looks like it has been undisturbed for a long time. Disconnect it from the engine, shine the ring terminal and the metal it contacts, apply a light film of vaseline or dielectric compound and tighten it down. Carefully check the resistance between the battery negative post and the engine. It should ne zero, clean it the same as stated above.
I should have as this at the outset; had the gauge worked before it smoked. What if anything had been done to the tractor just before it smoked. I have doubt that the sender was the cause but it is possible. There may be a gauge voltage regulator just for gauges that is faulty. You did mention that one of your other gauges was inoperative but not burned I believe. I don稚 recall seeing a regulator in your wiring diagram but it would be a good idea to carefully check for one. We will solve this mystery, hang in there.
Smilinjak
I cleaned the terminal, but didn't apply any dielectric grease. I'll do that. The temp gauge also doesn't work, stuck on cold, but doesn't show any sign of electrical overload. The only other "issue" the tractor has is I have to do the ole jiggly-wiggly with the forward-reverse lever to find the sweet spot in neutral, then the tractor will instantly turn over and start. That's probably the neutral safety start switch approaching retirement age and shouldn't affect anything else.
I asked my sons if they can think of anything not working properly. They reminded me of the time a battery charger was connected to the battery backwards. They were charging the battery with a low amp charger, I think it was 6 amps. As soon as the alternator started smoking and stinking "a little" (their words) they disconnected the charger.They said they told me about it, but I don't remember. Sounds like me when I was their age.:shocked:
The voltage regulator is part of the alternator assembly. Could it have been damaged by charging the battery incorrectly for a short time? Could that have damaged the fusible link? We might be approaching a conclusion...?..maybe.
