Newer 3/4 ton advice?
/ Newer 3/4 ton advice? #1
Fallon
Super Member
Parker, CO
Kubota L4060hstc, formerly L3200hst
A co-worker just agreed to buy my 2009 Tacoma & I'm finally ready to get a nicer, newer 3/4 ton pickup. I'm debating weather or not I'll sell the old beater F250 or trade it in. It's a bare bones work truck with a utility box & 250k. The Tacoma wouldn't pull 14k of trailer so I got the old F250. Now that the side gig doing tractor stuff is making a couple bucks I'm looking to consolidate down to 1 nicer truck. Maybe a beater econobox commuter car at some point as well, but I work from home most of the time so that's not important for now.
I'm looking for a relatively recent 3/4 ton double cab short bed with under 60k or so on the odometer. I'm kind of assuming a '16-'17. I want a diesel but that's not an absolute requirement. I'm aware what the price premium of the diesels is & the potential downsides of the emissions stuff (is it called tier 4 final like on the tractors?).*I'd like to be around $40k, but could swing a decent bit more if something with a diesel & nicer trim level tickled my fancy. I'd like adaptive cruise control & some of the other new safety features, but those only seem to be an option on the top trim level on 2018 or newer trucks, beyond my budget. Everybody has a backup camera now though with a nice sized screen which is so nice when hitching up.
I'm not looking forward to parking, but know what I'm getting into, hence wanting a shortbed. 260" to the shelf in the front of the garage & 280" to the wall, most shortbeds seem to be about 250" long & everything will be really close to the high 82" garage door. So I may or may not be fitting it in the garage, mostly due to height. I made the mistake of getting the access cab on the Tacoma instead of the double cab as I occasionally but not often need room for 4. I use the bed on the Tacoma a bit, but don't expect to use the payload of a 3/4 ton pickup, only the towing. If I need to haul more than fits in the bed, I have the 14k 22' trailer. No desire to go up to a 1 ton or dualy due to the potential CDL type ramifications over 26,001.
I went and looked at some trucks from the big 3 recently & came away not seeing to much different between them from just sitting & looking at options. Haven't gotten around to taking any for a test drive yet. I'm reasonably brand agnostic & sure I could get a lemon with any of them. I have little interest about the politics of any of them & what they have or haven't done in the past with bailouts or what not.
The 2005 V8 is barely adequate for my power needs up here at 7,000' in Colorado. Frustratingly slow on some hills at times with a full load on the trailer, but usually adequate. I'm guessing any of the current gassers would get the job done even better, but I still want a diesel even though I don't necessarily need one. That may mean ride quality may end up being more important to me, reliability definitely is.
Are there any big gocchas on the current crop of trucks engine, transmission or suspension wise? The older For 6.0l PowerStrokes had a handful of issues & the similar vintage V8 or V10s were a bit touchy about spitting sparkplugs & camshaft advance. The newer Fords seem to be a bit better machines, but I'm less familiar with the Chevy or Doge/Ram options or problem spots.
Anything I should look out for pro or con on any of the manufacturers? Any recommendations or comparisons I should pay attention when taking things for a test drive?
/ Newer 3/4 ton advice? #2
They are all so similar these days. It really comes down to, do you want ifs or a solid axle on the front. If ifs , gmc is your horse. If solid front axle, Ford or ram.
I'm at altitude as well. Turbos are our friend.
I have had good luck with Powerstrokes. 2015+ 6.7s are hard to beat.
/ Newer 3/4 ton advice? #3
How much tractor work work are you doing? As far as I’m concerned a ton or 1.5 ton dump truck is the handiest vehicle ever built. I sold my regular bed pickup 3 years ago and I have no plans of ever owning another one. A 3500 DRW and your current trailer both loaded to capacity wouldn’t exceed 26,000 pounds. Your trailer loaded to capacity and the truck mostly empty is well less than 26k.
/ Newer 3/4 ton advice? #4
If I was shopping for another diesel, I'd go with the Cummins in a Ram again. If shopping for gas I'd get a big block Ford. Any new vehicle will have a few recalls - even out to several years old. I recently got a recall on my 2010 Ram pickup - something about the park gear. Picking a new truck is probably pretty much a crap shoot for which is really better. They all do well if properly maintained and they all have more gizmos than is right for a truck in my opinion, but then again so do tractors.
/ Newer 3/4 ton advice? #5
82" garage height might be the deciding factor, lol. My 2008 Diesel crew cab Silverado antenna hits the 7' ( about 82") door trim at my house
/ Newer 3/4 ton advice? #6
I have a 2011 F350 with the 6.2l gas engine. Very capable engine; no issues with about 105,000 miles. Pulls 10,000 lbs easily (that’s the max limit on my trailer).
Don’t rule out the gas engine; less expensive and less maintenance than a diesel.
/ Newer 3/4 ton advice? #7
If you're set on the diesel engine, I wouldn't even look at a 3/4 ton truck. The extra weight of the diesel takes 700-900 pounds right off of the truck's rated payload sticker. I frequently see diesel 3/4 ton crew cab trucks with a payload rating of 2000 pounds or less. That is a joke for a work truck. Go 1 ton for diesel or you'll run out of payload way before you run out of pulling power.
The payload rating is what your hitch pin weight, or trailer tongue weight goes against. It's not just tow ratings you need to look at, but also payload ratings.
Go read a few door jamb stickers on diesel 3/4 ton trucks, especially crew cabs, it will be an eye opener.
I have a gas engine extended cab 3/4 ton, and my payload sticker is 3156. There's not a diesel 3/4 ton that can touch that number, especially in a crew cab.
/ Newer 3/4 ton advice? #8
An awful lot depends upon how the trailer will hook up to the new truck. Bumper hitch - frame hitch - gooseneck hitch.
Trailer is a 22' deckover power tilt bumper pull. It's only a couple years old & works well so not high on my list to replace. A gooseneck would be nice, but the old F250 wasnt really setup to take one. I may upgrade to a gooseneck at some point, but it will be a while after the wallet takes the hit for the new truck. 20191002_143957.jpg
/ Newer 3/4 ton advice? #10
With any DRW, he still needs a CDL and all the DOT crap. Trailer rated at 14k and a 3500 DRW is rated at 13k or 14k. To require CDL, it can be actual weight or combination of GVWR’s. I’m not sure where you got your information from, but it is incorrect. Loaded to capacity, he would be way over. He can get a SRW F-350/3500 with a GVWR of up to 12k and avoid the CDL, but no matter what he gets, he needs the rest of the DOT crap.
This is a good post.
Most trucks run out of payload long before their rated towing capacity, especially, with goosenecks.
The Ford. 6.2L gas is a great engine, but at 7,000 feet, the turbo might be the better choice. Generally, I recommend the gas for all towing at 15k and under (too many modern diesel issues) for everything except over-the-road trucking. Elevation being a constant issue as well as increased ability to pull and stop favors the diesel, in this case.
Your trailer is rated at 14k. That means you’ll need payload around 1,400-2,100 (tag or bumper pull) plus what you and other occupants and tools weigh. For a gooseneck you need the weight of occupants and gear plus 2,800-3,500 lbs.
in other words, having a payload over 3,000 lbs would be a good place to be, with a bumper pull and payload over 4,000 lbs, for a gooseneck. I would like to see close to 4,500, for the gooseneck.
/ Newer 3/4 ton advice? #11
You posted while I was typing. Look at a F-350/3500 SRW. GVWR should be 11k-12k, some may be derated, but that does you no good.
Gas versus diesel is a harder decision, with your altitude. I’ve read the gas does fine when passing through high altitudes, but don’t have first-hand experience enough to really comment on it.
/ Newer 3/4 ton advice? #12
What does having a DRW have to do with a CDL?
I've had a DRW for years, tow heavy at times, and never heard of that requirement. Only in Kansas maybe?
/ Newer 3/4 ton advice? #13
If your truck GVWR is over 26,000# and your trailer GVWR is over 10,000# you generally need a CDL.
Aaron Z
/ Newer 3/4 ton advice? #14
The DRW trucks have high GVWR’s. Why use a DRW truck if you aren’t towing at least 14k? If you’re actual weight or combined GVWR’s are over 26k (with at least 10k, for the trailer) and you’re in commerce (for money) you need a CDL A and all the other DOT crap. It’s Federal law. States may be more restrictive (California is really nuts), but not less restrictive.
If you’ve been working (tractor jobs) with a DRW towing “heavy”, you’ve just been running illegally.
ETA The OP said he has a 14k trailer. Any truck with a GVWR over 12k will require a CDL and all other DOT, for his business. Newer DRW trucks are all over that unless derated. Even with a half ton, he needs the DOT crap.
/ Newer 3/4 ton advice? #15
I’m not sure where all this CDL crap started because the OP doesn’t need one. While he doesn’t need a dually to pull a 14,000 pound trailer if he had a flatbed he could haul much bigger loads on the truck. And I stick to my original statement as being correct. Load the dually to capacity which is around 13k. Load the trailer to capacity which is 14k. Take out the overlap for the hitch weight minimum 1500 pounds and you’re under 26k. But all of the above is irrelevant. The dually with no load and the trailer is well under 26k. And the dually with no trailer even a 450/550 can’t be loaded to 26k so no CDL. The only way he needs a CDL is if he had a bigger trailer in which case the 250 can’t pull it so again it’s irrelevant.
/ Newer 3/4 ton advice? #16
You might catch more attention with a DRW but what exactly is the difference? I bet there’s not 500 pounds of difference between a dually and a 250. Both trucks will scale empty below 10k. Both trucks pulling a 14k trailer will scale under 26000. Both trailers are above 10000. I’m struggling to see the legal difference.
/ Newer 3/4 ton advice? #17
Oh boy more internet DOT lawyers. Can anyone post official proof that a truck with a GVW of 9999 or less that’s pulling a trailer thats 14,000 pounds while a truck with a GVW between 10,001-25,999 pulling the same trailer is illegal? If you have a truck that weighs over 26,000 and a trailer over 10,000 you need a class a CDL vs a class b. I’ve sure heard a bunch of rumors here but I’ve never seen any official proof that you need a CDL to pull a trailer over 10,000 pounds while keeping the total GCVWr under 26,000.
/ Newer 3/4 ton advice? #20
The DRW trucks have high GVWR痴. Why use a DRW truck if you aren稚 towing at least 14k?
Stability is why. I haul a cabover camper on my truck a lot. Used to have it on a SRW but since I take it off-highway I went to a DRW. World of difference having those two extra tires out there in an off-camber situation with a camper nearly 13' tall.
2006 Freightliner Tuscany 4077 40ft Class A Motorhome (A61574)
2006 Freightliner...
2004 Jeep Wrangler X 4x4 SUV (A61574)
2004 Jeep Wrangler...
2007 GMC C4500 Service Truck (A62679)
2007 GMC C4500...
35" EXCAVATOR BUCKET (A64280)
35" EXCAVATOR...
2023 New Holland C327 High Flow Compact Track Loader Skid Steer (A61572)
2023 New Holland...
2016 HAMM H7i SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7i...
