HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #51
My 2015 GC1710 with DL95 has what appears to be 1/4" ISO 7241 - A series. Is this correct? IMG_20191001_203857.jpgIMG_20191001_203917.jpg
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #52
I got a 2018 model. Having myself ordered the wrong male connect on Kenny's prv gauge, here's what I could tell you, go take another look at those couplers for any markings. On mine, the male connects just have some numbers that lead to nowhere on a google search. The female connects are Safeway 545-3P. I called Safeway, was told the male connects which match those are ISO 5676 3/8", which is what I ordered on Amazon yesterday.
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #53
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #55
Finally got a chance to try out the gauge, got a reading of ~ 1900 psi, so guess it's fine.
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #56
I got my gage as well. I'm definitely showing some weakness in my system, which is fine, as it definitely isn't used as a lawn mower. I measured out at about 1730-1740 PSI. I figured I was getting weaker when I tried to lift something heavy I lifted a couple years ago that I could no longer lift as easily or highly. I'll have to fix that in the next few days before I start my next project of adding dual rear remotes.
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #57
That male coupler looks smaller than mine. Mine are 3/8". You may have the 1/4", here.
I would agree with you.
Pretty sure 2016+ they went with the larger couplers.
I have the 1/4” on my 2015. Curious if it would make much of a difference to flow rate changing them to 3/8” ? Must have been some reason Massey changed them to a larger size.
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #58
Mine is a 2015 and I can confirm I had 1/4" fittings. I would expect a smaller size means faster flow as the pump volume is the same regardless of fitting size.
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #59
Don’t wast your money.
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #60
2017 Dodge Grand Caravan Van (A59231)
2017 Dodge Grand...
2012 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A60736)
2012 HEIL TRAILER...
1607 (A57192)
1607 (A57192)
Iranch IRGC40 High End Mini Golf Cart (A60463)
Iranch IRGC40 High...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58214)
1999 WEST WIND...
Volvo ECR235CL (A53317)
Volvo ECR235CL...
