Cutting corrugated roofing
/ Cutting corrugated roofing
I measure and then go order it cut to size so I'm not wasting money and I don't need to cut anything.. As a matter of fact I ordered some for my 12x20 shed last week, it will be here Wednesday all cut a in a nice neat package ready to be screwed down...
That is my preference as well. I can order 26ft at $5.50/ft plus taxes and shipping or I can buy this also new 12 ft at $3.33/ft, including tax, but I have to pick up, also 2 1/2 inches increased useable width, basically I less row. Significant cost reduction close to $1000.
/ Cutting corrugated roofing #42
I would go with a 4.5in angle grinder with a cutoff wheel. Thats what i used when i did mine. I have a plasma, circular saws and all kinds of metal working tools.
I feel like a plasma would burn to much of the coating. Circular saw with abrasive metal cutting blade would be my second choice. Cut them all at the same time.
/ Cutting corrugated roofing #43
Gotcha.. Delivery is free here so it's a no brainer for me..
/ Cutting corrugated roofing #44
a circular saw is clearly not the right choice, as it WILL throw large chunks of metal at you at high velocities. an abrasive cut off wheel is much better..
/ Cutting corrugated roofing #46
I've used circular saw & abrasive blades and ended up with burned edges, and lots of used blades. Got a carbide tipped metal blade, Still have the original blade after a barn and multiple sheds. I flipped the sheets to cut from the back. The pans then, are close to blade shoe for a clean cut. One other thing, placed a 2x4 under panel, at cut, to raise the ribs off the ground when cutting.
PPE is very important, save your hearing, eyes and skin.
/ Cutting corrugated roofing #47
This ^^^, though with either an abrasive or toothed 'cutter'tool use a guide for best/straightest/cleanest cut, least burring/heat, and leastchips/dust.
(has-been retiree flaunts trade experience)
Such as this, and half a dozen or more ways/methods/ideas mentioned/seconded are fine IMO. :thumbsup: Yeah, and don't we love TBN for just that? :)
Gotta love all the TBN knowledge 🤙🤙🤙
Seller offered to cut if I provide a cut list. Looks like I’ll take advantage and just do the width cuts myself with pneumatic shear.
/ Cutting corrugated roofing #49
I usually have used a wood framing blade turned backwards. Worked really well.
I did the same the other day and was having a harder time than before.
Got to looking and I was using a carbide tipped blade. (Which ruined it by the way)
Switching to an old cheap finishing blade 60 teeth ran backwards went like butter.
I usually run a flap disk on the edges after cutting.
Yes yes yes to ALL PPE! That’s a no brainer.
25026SFL (A61569)
25026SFL (A61569)
FIRST PRODUCTS 4 PRODUCT BALE SPEAR (A63291)
FIRST PRODUCTS 4...
Pull-Behind Spreader Tractor Attachment (A61572)
Pull-Behind...
10 ft bed. 14 ft trailer (A61567)
10 ft bed. 14 ft...
JOHN DEERE 620F FLEX HEADER (A63291)
JOHN DEERE 620F...
2007 John Deere 644J Articulated Wheel Loader (A59228)
2007 John Deere...
