Two injured seriously by farm tractor
/ Two injured seriously by farm tractor #1
msb1766
Guilderland, New York
SC2450 Cub Cadet/Yanmar
CLAVERACK (WRGB) Two men from Claverack are in critical condition after being rolled over by a farm tractor.
That's the report from Columbia County Sheriff David P. Bartlett, after deputies and multiple fire and rescue crews were called out at about 2:30 p.m. Saturday.
The sheriff's office, Greenport Police Department, Greenport Fire Department, and Greenport Rescue Squad all responded to the Jutofsky Farm on Route 23B for a report of two men seriously injured by a farm tractor.
Deputies found that Bernard Jutkofsky, 86, was operating an International Harvester 1066 farm tractor, towing a brush hog used for mowing fields. Jutkofsky had briefly stopped mowing, shut off the tractor, and stepped out of the cab. When he went to re-start the tractor, he did so from the ground, next to the engine. According to the sheriff's office, the tractor was still in gear, and when it started, Jutkofsky was run over by the rear tire. In addition, his son, Jay Jutkofsky, 48, was standing next to the tractor, and was also run over when it started.
Lifenet airlifted Bernard Jutkofsky to Albany Medical Center. Greenport Rescue transported Jay Jutkofsky to Columbia Memorial Hospital, from which he was later airlifted to Albany Medical Center.
Both are listed in critical but stable condition, with internal injuries.
/ Two injured seriously by farm tractor #2
Thanks for posting and sad to hear. Maybe the seat switch on newer machines isnt such a terrible thing? It is annoying, but better than getting run over.
/ Two injured seriously by farm tractor #3
Yeah, that is why they put them on there. Because there is someone always doing something they should have better sense than to do.
/ Two injured seriously by farm tractor #4
It's been a tough month for that area. I hope they have a speedy recovery.
/ Two injured seriously by farm tractor #5
A neutral safety switch would have been enough to prevent this accident. Probably no PTO safety switch either, lucky they didn't get mowed over.
/ Two injured seriously by farm tractor #7
I suspect the farmer screwdriver jumped the starter solenoid terminals to start the tractor, and no safety switch would of prevented it.
/ Two injured seriously by farm tractor #8
It a properly maintained tractor would not have required bypass starting. A tragic result of poor maintenance.
/ Two injured seriously by farm tractor #9
Ag tractors don't have a seat switch.
Many guys start their tractors that way. Not a problem if you pay attention. Maybe not a great idea for an 86 year old.
/ Two injured seriously by farm tractor #10
Exactly. Neither of my Kubota's do. Reason being is that at times you want to run the PTO when you aren't in the seat. Example would be powering a grain leg.
Common sense is supposed to prevail. Sadly, common sense takes a backseat often.
/ Two injured seriously by farm tractor #11
I'm surprised that the battery was able to start it while in gear.
/ Two injured seriously by farm tractor #12
OH, trust me, they will start the engine while in gear, AND will move the tractor at the same time. There is a lot of torque in a starter motor.
/ Two injured seriously by farm tractor #13
I know that a gas engine will with no problem, yet my old 275 would just click if I had it in gear, no matter what I put in it for a battery.
/ Two injured seriously by farm tractor #14
Carelessness... This is what happens when we become complacent about our machinery. I hope they recover quickly, they are very lucky to be alive.
/ Two injured seriously by farm tractor #15
Gas or diesel, doesn't matter.
The starter will move and start the engine in gear
/ Two injured seriously by farm tractor #16
I have an ancient John Deere 2020. It CANNOT be started unless the transmission is in Park. I think that International 1066 was about the same vintage; I'm thinking someone disabled the safety feature!
/ Two injured seriously by farm tractor #18
And because of guys like that, the rest of us have to suffer with and pay for all kinds of safety equipment.
Like someone correctly stated. Shorting the starter at the starter, bypasses ANY OEM safety systems.
Amazing how much misinformation exists on the Internet.
/ Two injured seriously by farm tractor #19
In my previous post, I was not referring to a seat switch. My Mahindra has a switch at the shuttle lever to detect neutral and a switch at the PTO lever to detect the off position. It can't start if either is in the wrong position. Once started you can leave the seat regardless of the shuttle and PTO levers positions.
Sounds like "many guys" should learn a safer way to start their tractors.
/ Two injured seriously by farm tractor #20
No, you still don't understand. Shorting the starter at the starter basically connects the solenoid right to the battery. The starter is already, always connected to the battery.
Amazing how so many people think that an 86 year old is going to recover and get better.
BOX BLADE (A58214)
BOX BLADE (A58214)
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
TRI PAC EVOLUTION APU (A60736)
TRI PAC EVOLUTION...
30KW GENERATOR (A58214)
30KW GENERATOR...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
207274 (A52708)
207274 (A52708)
