Fitting supplier
/ Fitting supplier #1
Bsavulis
Member
Putnam, Connecticut
Kioti CK25
I am looking for a supplier of socket weld jic 6 fittings. I need 90 degree ells, branch run tees, and straights. I am also looking for a supplier for the appropriate mild steel tube. My FEL has all rubber hose that I would like to replace.
Thanks for any info!
Brian
/ Fitting supplier #3
In my industrial piping days such items came from industrial piping suppliers. Never saw a socket weld JIC. They must larger than any hydraulic system I worked on. Usually any thing larger than 3/4" was flanged or pipe thread. Find a supplier of Swadgelock compression fittings made for hydraulic service. Installed 100s of those. That way you do need to have an expensive flaring tool. Largest hydraulic system in my past was 3" triple heavy welded steel pipe. 10,000 PSI if I remember rightly. Believe me cleanliness was a problem. WE installed filters at every branch line and before every device.
Buy Fittings | Swagelok
Ron
/ Fitting supplier
Thanks for the info, I did not know that Swageloc made that type of fitting. I just got a quote from a supplier .. 20.pcs of jic 6 to 3/8 tube, 6pcs of jic 6 female to male 90 ell, and 4 pcs of jic 6 tee... almost $900.00. OUCH!!!!
Putnam is in the northeast corner of CT. I am about 3 miles from the RI border, and 5 miles from MA.
/ Fitting supplier #6
Did they quote steel or stainless steel. SS is probably more the twice as much especially 316 rather than 18-8. 316 is food grade. They were always expensive but saved a lot of labor time. I have not bought any for 30 years. They have several pressure ranges also that affect price.
Ron
/ Fitting supplier #7
This is what you need
/ Fitting supplier
That is exactly right! Just can't seem to find them at a reasonable $. I was looking for mild steel, but seem to only be able to find the 316 ss parts. With so many tractors with hard lines on their FELs you would think that the parts would be all over the internet. I can only find aluminum fittings for fuel related applications on Ebay.
At he prices I have been quoted I may just leave the rubber lines.
Brian
/ Fitting supplier #9
Brian
Those fittings should be available in forged steel. Mild steel would probably meet the PSI rating you need. Mixing SS fittings with steel hydraulic tubing may be little dicey as they are designed for TIG welding. There are other brands of compression type fittings that may be cheaper. JIC requires a 37 degree flaring tool which if I remember correctly are about $300.
LOL, Ron I will be watching this.
/ Fitting supplier
So I thought I would post a brief update to this project. I have had very little time to put on this project in the past couple of months. I have made mounts for the new lines, silver soldered the assemblies, and have done a trial fit. Attached is a before picture and photos of the lines during the trial fit.
/ Fitting supplier #11
Nice looking work, well done. I, hope those flare fittings are JIC 37 degree flares. Standard hydraulic hose fittings will not seal properly on the industry type 45 degree flare, we all are familiar with on our gas and water systems. On flare to flare tubing we usually did the tube flare as the double type. Yes, on industrial piping (my old trade) we ran into projects with JIC fittings. Had to be careful with steel/SS tube deforming between 37 and 45 degrees. Steel/SS were not as accommodating.
Where did you finally find the forged steel fittings?
Again nice work, Ron
/ Fitting supplier
Thanks for the complement. My first time making lines, the real proof will be when I put pressure to them. The fittings came from Curtis Hydraulics in Hooksett NH.
/ Fitting supplier #13
Looks better than all the hoses.
Did you look into buying the hard lines from a dealer?
Both of my tractors use oring boss to flat face oring adapters. The hard lines all have the flat face oring fittings.
/ Fitting supplier
The OEM is the hoses, they did not have solid lines available. The hoses originally were ran down inside the loader arm and through the center torque tube. I have a thread here of the issues I ran into when I went to add my home made grapple. https://www.tractorbynet.com/forums/kioti-owning-operating/409821-mouse-nest-turns-into-can.html
YES all the hoses in the picture were buried inside the loader arms and the center cross tube originally. Most of the OEM hoses are JIC6 on one end and JIC5 on the opposite end.
/ Fitting supplier #16
Then real secret to successful sil-braze is clean thoroughly, proper flux, proper alloy (min 25% silver), evenly heat the socket and filling the socket with alloy. Material on top provides no added strength.
Ron
/ Fitting supplier
Ron
Ron,
I gave sockets of the fittings a bead blast, and purge with air. Then wiped down with acetone. The tubing was wiped down with an acetone soaked piece of scotch-brite. I used Harris Safety-Silv 45% with Harris Stay-Silv Black High Temp Flux. I did see the solder wet into the joints so I am hoping it all works out. If a fitting does leak anywhere I will probably have to re-fabricate the entire tube. I don't think I would ever be able to get the oil cleaned out enough to get it to seal up. I hope to put it back together and test it this weekend during the heat wave we will be having. (low 60's)
Thanks
Brian
/ Fitting supplier #18
Ron,
Thanks
Brian
Brian, great work, you did it just right. My go to silver braze alloy. Yeh, the existing are the hardest to braze due to the residual oil. In reefer work we ran into that a lot. Clean back with the solvent as far as you can and make sure there is no outward flow and you will be OK.
With you on getting a weather break to work outside, we have had constant rain for the last 4 weeks. Breaking records, even here in the wet Puget Sound area. Temps are mild (above) 35 but wind and rain keep me inside.
Ron
/ Fitting supplier
Ron
:cool2::confused2::licking::thumbsup::dance1:Yup thats right NO LEAKS!!! Whoooo Hoooo! Thanks to everyone for the advice and encouragement!
Brian
2017 CATERPILLAR 242D SKID STEER (A62129)
2017 CATERPILLAR...
2004 Chevrolet Silverado Pickup Truck, VIN # 1GCEK19T04E260216 (A61165)
2004 Chevrolet...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2019 Caterpillar 239D3 Compact Track Loader Skid Steer (A61567)
2019 Caterpillar...
CRAFTSMAN 20 GALLON ELECT. AIR COMRPRESSOR (A62131)
CRAFTSMAN 20...
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
