5085M Lights Stay On
   / 5085M Lights Stay On #1
spray004
2015 JD 5085M
My dad has a 5085M open station tractor he uses sporadically around the farm. Last week his headlights would not turn off unless he disconnected the battery. We have since figured out if the hood of the tractor is open, the lights will stay off. Once you close the hood, they come back on, regardless of the position of the switch. When the hood is up, the switch operates as normal. Does anyone know if the light switch acts as a ground circuit or a positive circuit? I cannot find any electrical wiring diagrams when searching Google.
   / 5085M Lights Stay On #2
:welcome: to TBN
I'd check with the Deere dealer and ask for a screen shot of the electrical schematics. They can pull that up for you, if they want to do it. It's a good test of a helpful dealer.
   / 5085M Lights Stay On #3
Is the hood pinching the wiring?
That's my gut feeling, but dad can't see where it's pinching at. If the hood was pinching a wire, my first gut feeling that it's completing a ground circuit somehow causing the lights to come on. If I can get a wiring diagram I can figure out how the lights are circuited without having to tear into the wiring loom blindly.
   / 5085M Lights Stay On #5
The switch definitely works by sending power to light relays, dimmer switch and lights. It does not complete circuit to ground. It is puzzling to hear the way it is working. Sounds like a wiring issue. Maybe a 12 volt wire is pinched against the light power wire when hood is closed. Or harness may be against hot post on alternator? At first I was thinking a sticking relay for lights staying on, but opening the hood should not affect that.
1995 Olympian Generac 94A06155-S Generator (A49461)
1995 Olympian...
TTS5-10680 Rubber Tire Asphalt Roller (A49461)
TTS5-10680 Rubber...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
1269 (A50490)
1269 (A50490)
2013 JLG 8042 TELEHANDLER (A50854)
2013 JLG 8042...
AIR POWERED TONGS (A50854)
AIR POWERED TONGS...
