Easiest method to fill with diesel
   / Easiest method to fill with diesel #11
I built my own tank to fit in a full size pickup truck. Deliberately kept it lower than the cab’s rear window for driver visibility.
   / Easiest method to fill with diesel #13
   / Easiest method to fill with diesel #14
When I bought my first tractor, I went ahead and bit the bullet. Got a 100 gallon steel tank and 15 GPM 12 volt pump (both used) for $350. Been using it for 10 years now without a problem other than the auto cut-off nozzle started tripping off and hard to get started, so I replaced that. No issues with the pump. After a couple of year of using a jump start battery pack, I bought a small car battery that I keep attached to the pump with a battery maintainer hooked up. Same battery now for 8 years and still going strong. It just doesn't get any easier than pulling up to the shop, flipping on the pump and filling the tank.
I initially got the 12v thinking I might need to put it in my truck but that has never happened. I get fuel delivered in bulk right to my door. I did have to get an additional tank after the bulk sales guy upped the required purchase amount to 150 gallons or else I had to pay a delivery charge. I just got a free TOTE TANK from a local chemical company and use that to make up the required amount to deliver.
   / Easiest method to fill with diesel #15
Wow. A lot of overkill posted here. I set a 5 gallon can of diesel on the tractor hood and use a giggle siphon to transfer the diesel from the can into the tractor. Super fast and no expensive pumps
   / Easiest method to fill with diesel #16
Let me guess....you are under 70 and/or do not have rotator cuff issues? Does your wife/GF ever fill your tractor or pick up fuel in those jugs?
I like having a 50 gallon tank that I can easily put in my truck bed with forks and fill with off road. I store it in the garage on two HF dollies and it takes less room than a bunch of jugs. I have $150 into my setup (tank, 12V pump, wood frame, dollies). If it lasts 15 years, that is $10/year.
No loose jugs in the back of the truck. No spilled fuel.
And my fiancé can easily fill the storage tank, off load it, and fuel the tractor. That has value to me at least.
   / Easiest method to fill with diesel #17
Overkill is a relative term. I go by the "work smarter, not harder" principle.
For me, a truck mounted 12v commercial transfer pump with auto shutoff nozzle is the method of choice. Zero lifting, zero spilling / over filling.
   / Easiest method to fill with diesel #18
This year, the card that my daughter gave me for Fathers Day included a 4" x 6" magnetic sign,,
The sign says
"No job is too small for a BIG expensive power tool,,,"
That saying applies to me fueling the tractors,,, :D
   / Easiest method to fill with diesel #19
The sign says
:thumbsup: LOL
   / Easiest method to fill with diesel #20
I think the amount of fuel used makes a lot of difference.
I use 2,500 gallons per year. That's 500 five gallon jugs.
I have a transfer tank mounted in my truck. Rarely touch a 5 gallon jug.
Plastic Buck Statue (A55853)
Plastic Buck...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
2013 FREIGHTLINER CASCADIA SLEEPER (A53426)
2013 FREIGHTLINER...
CAT 416B (A47477)
CAT 416B (A47477)
1340 (A57192)
1340 (A57192)
