Should I Dump Almost 5 Gallons of Diesel?
   / Should I Dump Almost 5 Gallons of Diesel? #32
Someone message steveky to ask if the harmonics in his regulator were thrown off by the stabil, causing him to need new muffler bearings.
   / Should I Dump Almost 5 Gallons of Diesel? #33
Do you heat your home with #2 heating oil? If so, you could pour it in that tank if it makes you feel better and it won't be wasted.
   / Should I Dump Almost 5 Gallons of Diesel? #34
That's about as much as a Massachusetts politician is native blood.
Or....ten times the weight of Trump痴 brain...lol.
Sorry, hard to resist when someone has to inject politics into everything.
   / Should I Dump Almost 5 Gallons of Diesel? #35
Bottom line, you probably got worse out of the pump without knowing it.....
It will be fine, just run it.
I'm the original poster. Called Sta-Bil. Asked if there was anything in the stabilizer that could harm my tractor. He asked which color I used. I think he said red, yellow, or blue. I said red. He said no problem.
   / Should I Dump Almost 5 Gallons of Diesel? #37
Kind of what we all figured... :)
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
2015 SKY TRAK 6036 TELEHANDLER (A57880)
2015 SKY TRAK 6036...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A55315)
Galvanized...
Pallet of Vehicle Seats (A54816)
Pallet of Vehicle...
3-Ton Gantry Shop Crane (A54816)
3-Ton Gantry Shop...
