OEM Fluid Filters for Yanmar 276D
   / OEM Fluid Filters for Yanmar 276D #11
Right here.
   / OEM Fluid Filters for Yanmar 276D #12
Thanks Winston. As always you are a wealth of knowledge and resources.
Thank you Winston1, I appreciate the help. Is 31 the screen? Is this screen usually cleaned rather than changed? I will try and look at it tomorrow. Thanks again!
   / OEM Fluid Filters for Yanmar 276D #14
I'm glad to hear it's cleanable! I bought the Filter, it came up as a Baldwin B2 at my local Tractor store. I'll have to take a peek and see if the screen is accessed easily. If not I may wait for my help to return. Thanks again!
   / OEM Fluid Filters for Yanmar 276D #16
just an FYI.. Before you pull that cover to access that filter screen. Drain your HYD oil
If you remove that cover with HYD oil in the tractor, You'll be covered in oil, as it will all come out at once when you pull that cover
Thank you, I appreciate the information! Will do! We changed the Oil and Filter today as well as the air filter. I was surprised that the oil filter was actually recent but the hydraulic filter doesn't look like it is too recent. Maybe tomorrow I will get to it but very soon either way!
2014 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2014 GENIE...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2018 PETERBILT 579 DAY CAB (A51222)
2018 PETERBILT 579...
2013 PETERBILT 367 (A50854)
2013 PETERBILT 367...
1267 (A50490)
1267 (A50490)
2005 STERLING LT8500 SERIES MIXER TRUCK (A50854)
2005 STERLING...
