Pat's Quick Hitch Pointers
/ Pat's Quick Hitch Pointers #1
Dranrab
Perkinston MS
Mahindra 1626 HST
Hi folks. It's your resident n00b again. I hate being the n00b asking all the new guy questions, but I am the new guy and I do have questions. Thanks for suffering/indulging my ignorance.
On the recommendation of quite a few folks here I ordered Pats Quick Hitch. I later learned that there was a spreader bar that can be used with it. Is the spreader bar necessary? Since I will be out at my acreage and away from most of my tools when I install them, what will I need to get them properly installed?
/ Pat's Quick Hitch Pointers #2
Not necessary, but the spreader bar is handy, and only temporarily used, when backing up to the attachment to keep the tractors lift arm at the correct width apart to align with the attachment's pins. A bungy cord and a stick would do the same thing.
Thanks Coby. Does the quick hitch need and/or come with bushings?
/ Pat's Quick Hitch Pointers #4
The bushings, if needed, go on the implement ears.
/ Pat's Quick Hitch Pointers #5
As said above it’s handy but not required. My opinion is if you spend the money on the hitch why hassle with sticks and bungees etc when the whole purpose of the hitch is to make life easier. I have my spreader bar marked for the width of different attachments. If you bought a cat 1 you shouldn’t need any bushing for cat 1 attachments.
/ Pat's Quick Hitch Pointers #6
Used to struggle but here's what I did.
The four 5/16 screws can angle your hitch inwards/outwards.
Mine are now adjusted to where both will slide in up against the inside portion of the implement, then the arms will spread slightly and hitch right up easily.
/ Pat's Quick Hitch Pointers #7
You can make your own spreader bar, using a piece of 3/8 rebar bent down at each end.
One bar for each different width implement.
/ Pat's Quick Hitch Pointers #8
As oldballs mentioned, the bushings are for the implements you're going to use with the quickhitch. Two per implement on the lower pins. Typically, the bushings are a standard length/diameter for your Category however (and there's always a 'however', isn't there? :laughing:) sometimes you'll require an extended bushing. [My 'gratuitous' JD ballast box needed those]
Bushings are a separate purchase and can be found at any rural supply shop or dealership. Get a set for each implement you're going to use with the quickhitch... plus a spare set for future use.
Does the quick hitch not ship with any bushings?
/ Pat's Quick Hitch Pointers #10
I don't know (I've got a JD iMatch quickhitch). The Pat's system might. :confused3:
If it does it will only be one set, which you would then have to swap around with all of the other 3PH implements that you have or will get in the future... which kind'da defeats part of the purpose of the 'quick' part of the 'quickhitch'. :)
Addendum: I just clicked on the (blue) link to the Pat's quick hitch, offered by/via TBN... it's just the two-piece hitch. A stabilising bar is offered, for an added price.
NO bushings included.
/ Pat's Quick Hitch Pointers #11
If you buy the Cat 1 hitch and you have Cat 1 attachments no bushings are needed.
/ Pat's Quick Hitch Pointers #13
Not being familiar with your tractor, does your 3pt have telescoping stabilizers or turnbuckles?
If telescoping, use them to space the arms correctly.
/ Pat's Quick Hitch Pointers #14
The bolts included to position the Quick Hitch are too soft and will mushroom when tightened making them difficult to impossible to remove later. I purchased 3/8" set screws and replaced mine.
/ Pat's Quick Hitch Pointers #15
Agreed.
My question is, and I've never got a good answer: Why do they have to be tightened?
The Pat's System "grab hook" eliminates the function of the ball swivel at the end of the tractor's lift arm. So if the Pat's "hook" is properly perpendicular to attachment pin when arms are lowered, this alignment between "hook" and pins gets cocked when lift arms are raised, which puts a twisting side pressure on the Pat's and compression on these bolts that cause them to bend or mushroom head.
I'm tempted to leave a 1/4" gap between each bolt and the lift arm so the Pat's can "swivel" in the ball at the end of the tractor's lift arm. Is there a reason I shouldn't?
Right now my PAt's are at machine shop trying to get out the bolts that bend, then snap at the bolt head when you try to remove them. (I should of cut them off inside the Pat's before attempting). I also get sick of re-aligning the Pat's on the lift arm with these bolts when I switch from a Cat I to Cat II attachment and lift arm separation width changes.
/ Pat's Quick Hitch Pointers #16
Agreed.
The Pat's System "grab hook" eliminates the function of the ball swivel at the end of the tractor's lift arm. So if the Pat's "hook" is properly perpendicular to attachment pin when arms is lowered, the attachment pin is cocked when lift arms are raised, which puts a twisting side pressure on the Pat's and compression on these bolts that cause them to bend or mushroom head.
Right now my PAt's are at machine shop trying to get out the bolts that bend, then snap the bolt head when you try to remove (I should of cut them off inside the Pat's before attempting). I also get sick of re-aligning the Pat's on the lift arm when I switch from a Cat I to Cat II attachment.
I've noticed that if the bolts become loose and the hitch becomes slightly canted, it can be very difficult to get the hitch pin out of the hitch.
I'm wondering if the bolts are intended to keep the hitch in line with the 3 point arm to prevent this.
This does create the problem you mention with the bolts though ("compression on these bolts that cause them to bend or mushroom head"
So I dunno.
/ Pat's Quick Hitch Pointers #17
The bolts do mushroom not a lot but enough to prevent removing them. This hasn’t been an issue for me. When I need to remove them to put my backhoe on I just loosen the bolts pull the ball pin and take it off with the bolts still on. If I ever have to remove them I figured I either cut the bolts off on the inside somehow and back them out normally or cut the heads make a slot and screw them in till they fall out.
/ Pat's Quick Hitch Pointers #18
If you research this product on the forum, you will see a number of recommendations to replace the bolts with Grade 8 or the like. I read it, but didn't bother because of the light use of my tractor. It was a mistake as the the bolts ended up stretched and some could not be removed. Someone on the forum said to cut them on the inside, and I should have followed their advice as it would saved me the headache of getting them stuck.
The manufacturer seems to have a good reputation on the forum, and comments indicate good customer service too from what I read. Why they choose to sell these with such cheap bolts given the stresses involved is beyond me. I'd prefer they charge an extra $2. If they've changed this in the latest versions, please ignore my comments as mine are several years old. I'm going by what I see online as to the bolts provided.
Telescoping.
The hitches come in today. Can someone show me exactly which bolts need to be replaced.
1999 Kawasaki 1100STX Jet Ski (A61165)
1999 Kawasaki...
2013 International WorkStar 7400 4x4 Altec AM547 50ft Material Handling Bucket Truck (A61568)
2013 International...
Vermeer 5725TX Mini Skid-Steer (A61166)
Vermeer 5725TX...
UNUSED RAYTREE RMSC78 - 78" HYD SOIL CONDITIONER (A62131)
UNUSED RAYTREE...
2020 Ford F-150 Pickup Truck, VIN # 1FTEX1C57LKD02991 (A61165)
2020 Ford F-150...
40ft Six Section Heavy Duty Metal Storage Shelf (A64047)
40ft Six Section...
