Understanding Error 008
/ Understanding Error 008 #1
tkh159
macon GA
Kioti DK40 Kioti NX4510 HST
I purchased a new NX4510 over the weekend and had a backhoe put on Monday so today was the first day I have operated the tractor. It was delivered and I got home and unfortunately it would not start and had the error code 008.
Dealer said it's nothing to worry and said it won't start cause I'm not heavy enough at 140lbs and he seemed to think the sensor didn't recognize me sitting on the seat so he said adjust the firmness down and compress the seat a couple times aka jump up and down.
So anyway the tractor did start whether or not that had to do with seat firmness adjustment and jumping on seat I do not know.
Enough with the ramble. My question is will the tractor start with that error code 008 ?
Its unclear to me what the code means, does it mean there is water in the fuel OR that the system cannot detect the sensor that detects water?
Any help is much appreciated as I'm want to be informed that I know what I'm asking the dealer.
/ Understanding Error 008 #2
System can’t detect the sensor. And yes it will start and run even with that error code.
Thanks countrybumpkin. I'll ask them to replace the sensor or do they need to clean it or maybe even reconnect it?
/ Understanding Error 008 #4
CB, when I had the 008 code on my tractor with the Regen issues that I have been having, I was told that Kioti's have a problem with ghost codes showing up. I found that to be interesting.
/ Understanding Error 008 #5
Error Code 007 and 008 are only signally a "Safety Start" fault. The error codes in the Operator Information window on the instrument cluster are only signally faults in the Safety Start system, and have nothing to do with the Engine ECU. If the operator forgets to meet one of the Safety Start requirements, in the seat, range in neutral, ect., you will get one of the error codes in the dash unit. Once the safety start requirements are met, the tractor will start and the error code will remain for a couple seconds, then disappear.
Important to know that the error codes on the dash unit are ONLY Safety Start errors, and have nothing to do with the Engine ECU and Fault System. The NX Tractors have a separate Safety Start System that is read through the operator information in the dash unit.
Hope this helps.
/ Understanding Error 008 #6
I find it hard to believe that you are not heavy enough to trip the seat switch, if it was a seat switch issue, sounds more of a loose connection or switch malfunction. Mine didn’t take much pressure, I could reach up in the cab and press down with my hand and activate the switch but I’m not sure how the newer seats are. Mine will not start if the brakes are not coupled together and foot on the brake. Mine is a shuttle shift however.
/ Understanding Error 008 #7
I find it hard to believe that you are not heavy enough to trip the seat switch, if it was a seat switch issue, sounds more of a loose connection or switch malfunction. Mine didn稚 take much pressure, I could reach up in the cab and press down with my hand and activate the switch but I知 not sure how the newer seats are. Mine will not start if the brakes are not coupled together and foot on the brake. Mine is a shuttle shift however.
On my Kubota L48 TLB, exactly ZERO pounds on the seat is necessary to start the tractor!
I think.....the "seat switch" is somewhere in a box.....,maybe on the third shelf down from the top.
They have it in the shop and I'll ask the question cause after looking through the manual all I was doing was adjusting seat firmness. It was behaving a lot better but still needs to be looked into.
I also am having them look at the range shift as I only had Medium and neutral....womp womp
/ Understanding Error 008 #10
I thought ERR-008 error was water in the fuel (page 4-32 in your owner's manual). Unplug the fuel sensor at the bottom of the fuel filter and spin it out until the water pours out, then tighten it back up again. Prime the fuel system again and go start up the engine.
620906d1568274661-understanding-error-008-a-screen-shot-2019-09-12-a
Thanks Eric I'll give this a try if I see it come up again.
/ Understanding Error 008 #12
No it’s not Eric , the dash cluster has a light that illuminates if the sensor detects water. Look at the photo you attached, it clearly says what 008 is.
/ Understanding Error 008 #13
Not sure I understand your response. From the picture Eric attached, it says error code 008 is "No Signal at Water IN FUEL input". I'd take that to mean there's an issue with water in the fuel. Are you saying it's an issue with sensor signaling (as in no voltage detected) vs. sensor activation (as in water in the fuel)?
/ Understanding Error 008 #14
Yes that’s what I’m saying.
/ Understanding Error 008 #15
Ah, okay. I think it's easy to make an assumption either way, given how poorly the manuals are written.
/ Understanding Error 008 #17
Just Trying to save you some time here...concentrate on the Safety Interlocks in the tractor:
Seat Switch
Range Switch
Pedal Switch
PTO Off
Etc.
If the Safety Controller does not see Safety Start, it won't send a signal to the ECU for "Tractor Ready". This is the condition that will cause the 007 and 008 Error Codes. We have even seen where a faulty tail light harness will cause this (Error 008) since it is on the Brake Pedal, which illuminates the brake lights when the pedal is pressed for "Safety Start" condition.
Hope this helps,
Seat Switch
Range Switch
Pedal Switch
PTO Off
Etc.
Hope this helps,
On that note my tractor is stopping or trying to when I'm going through bumpy terrain. Turns out since I'm about 130-140 lbs when I hit a bump it's just enough to raise myself off the safety switch so the tractor thinks I'm getting off and then tries to shut off. I understand its purpose though.
This is a annoying issue that i didn't have I'm my DK40. I have not found a work around and the dealer won't tell me if I were to ask and I cant same I blame them but it's an unpleasant ride when your getting jerked around.
/ Understanding Error 008 #19
If it's the seat switch, a small piece of wire jumpered between the seat switch wire contacts will resolve that. You can at least test the seat switch using this method, to actually figure out if that's what is causing the issue. Easy enough to switch back to the original "safe" configuration.
It is the safety seat switch for fact. I thought about what you mentioned. I'll have to locate the switch or plugs and see if I can access them.
2021 CATERPILLAR 303.5E2 CR EXCAVATOR (A62129)
2021 CATERPILLAR...
2022 All Aluminum Timpte 514 Trailer Electric Tilt (A63118)
2022 All Aluminum...
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63118)
2023 Kubota...
2017 JOHN DEERE 350G LC EXCAVATOR (A62129)
2017 JOHN DEERE...
2020 CATERPILLAR D5K2 LGP CRAWLER DOZER (A62129)
2020 CATERPILLAR...
