A couple things I noticed underneath my GC1710
   / A couple things I noticed underneath my GC1710 #33
My 2017 GC 1715 manual does not show them either... That is why the edit of manual page... By the way they are on outside of sub frame rails...
Dale
Yeh thanks man, I'll check them out when I'll have a chance.
   / A couple things I noticed underneath my GC1710 #36
Thanks for the video and tip, out of curiosity did you try to use a grease needle on those or did you just go to the new zerk?
Jim.
Jim.
Imold, would you be able to get at it as is with a grease needle? Maybe. Would it be a hassle? Most definitely. With all them zerks to hit on the tractor, I'll take easy peasy lemon squeezy. :cool2:
   / A couple things I noticed underneath my GC1710 #38
The hassle is the part I was wondering about, using the grease needle is not the hard part but the approachability of the zerk with the needle was what I was looking at, I am going to look into a few zerk adapters like those 45* ones and put some in my tool kit for that just in case moment, I have never seen a 45* zerk you can take apart like that normally the ones I have seen are solid 30* or 45*.
Jim.
   / A couple things I noticed underneath my GC1710 #39
Jim.
The same here, which is why I suggested the 'extension'.
"Today I learnt..." Hooray for TBN.
Jim.
Guys, don't you have that zerk there? Just look down there and see how you'd grease it as is. Alls I could say is, that zerk that massey ferguson put there in that spot, it was blatantly an afterthought. No, it would not be easy hitting it with a needle. Yeh, there are a couple things I noticed on this tractor that are a little bit afterthoughty.
2015 Infiniti QX60 SUV (A56859)
2015 Infiniti QX60...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
JCT 72" Skid Steer Rotary Brush Cutter, Asset# 68 (A59076)
JCT 72" Skid Steer...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
60in Forks (A56857)
60in Forks (A56857)
